Question about Bose (321GS) System
How do I turn off closed captioning on my Bose 321?
SOURCE: Bose 321
Same problem..it was working fine, shut off to untangle cords & it would not turn on
Posted on Dec 09, 2007
SOURCE: bose 321 cd/dvd tray stuck closed
can you post the disassembly page in with a larger view? This is too small to be useful
Posted on Jan 19, 2008
freetek
  • 5568 Answers
SOURCE: Bose 321 won't turn on
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
Posted on Oct 17, 2008
SOURCE: communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Posted on Feb 13, 2010
futurework
  • 70 Answers
SOURCE: Bose 321 won't eject DVD
the dvd system is built around a pc style dvd rom drive. You can remove the top cover by prying the back center up and sliding the cover back then off. Remove the metal bracket that holds the drive in place and then remove the drive. the front tray cover should pop off as you remove the drive. There is a eject hole in the front that if you put a paper clip into it will release the tray. That way you can get your dvd back. I refurbish these drives and I may have one for sale. Contact me if you would like to send the unit in to me i can complete the repair for 85.00 Bose does offer a repair service if you call them at 1-800-999 2673
Posted on May 04, 2010
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
NO CLOSED CAPTION VIA BOSE LIFESTYLE 20 SYSTEM
CC is a function of your cable box in this case. TV's have the feature as well, but Bose is right about not all HDMI devices supporting CC through HDMI, especially converting from component to HDMI before hitting your TV. The solution: call your cable provider for this. Start at the source. The cables you use or the TV won't 'take away' closed caption if it's already there.
Feb 19, 2009 | Toshiba MW20FM1 20 in. Combo
Bose Model 321
the bose will not play anew dvd comes up need paasword
Aug 08, 2008 | Bose Wave Radio
Bose 321
got the same problem
Jul 05, 2008 | Bose (321GS) System
Bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Nov 13, 2007 | Bose 3 2 1 GSX System
Bose (321GS) System Logo
261 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
