Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Tv comes on with top left screen distorted after 2 min powers off then front light blinking three times HELP
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
You should be able to get a local service center to repair this at
your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and
heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old
heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center
circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews
Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their
phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the
phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a
good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this
information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Nov 16, 2009
Testimonial: " Thanks for the help"
I replaced three cans. they were bulged on the top. i plugged the tv in and it did the same thing. i said it blinks 4 times fast but it is only three. blink code says 3=RESERVED. i pulled the the y-sustain...
Philips lists 3 models of your TV:
1) 50PFP5332D/37
2) 50PFP5332D/37B
3) 50PFP5332D/37E
User Manual for your TV (actually for the 50PFP5332D/37E):
http://download.p4c.philips.com/files/5/50pfp5332d_37e/50pfp5332d_37e_dfu_aen.pdf
The user manual doesn't document the logic board blink codes for errors.
What this tells me is that the TV went thru two revisions before reaching version E.
in case it helps: Philips Customer Support: 1-888-PHILIPS.
If they can't help otherwise, they can at least tell you if your set is eligible for warranty service.
Mar 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
Sep 24, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
Powers off intermitantly
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Screen is Black Power Light Blinks Three Times
bad power sorse bring the tech in unless u know how to chage outthat part
Mar 15, 2008 | RCA HD52W59 HDTV Projection Television
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
