Question about Xerox WorkCentre M15i Laser Printer
Document feeder on the Xerox M15i seems to spin and not accept pages. Replaced roller but problem still exsist.
  • 239 Answers
When replacing the feed roller make sure you put it on right, If it is on backward the roller will just spin, because they have one way clutches in the feed roll itself.
Otherwise I would need more information about the document feelder problem.
Posted on Nov 29, 2009
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
Document Feeder Jamming.
The feed rollers may be worn out and need to be replaced, you can try cleaning the rollers with some alcohol, this may also make it feed better. but if it starts to act up again it might be time for new rollers.
Hope this is of some help.
Ed
Apr 30, 2009 | Office Equipment & Supplies
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
The Automatic Document Feeder (ADF) is not working.
Mark,
A little help here, what machine are we talking about. Do you here any thing moving?
Richard Eklund
ITWorkz
512-589-6410
Mar 05, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox WorkCentre M15i squeals when printing and copying.
Do not only lubricate metal shafts, but promptly lubricate the "pulleys" on the right and left side.  the will look very similar to a wheek and pulley mechanism.  The squeal happens when one "bar" connects two "wheels" and one side moves faster than the other.
Jan 23, 2009 | Xerox WorkCentre M15i Laser Printer
Paper Feed Wheels
Yes thats easy to fix.
Unplug the machine, unplug the connector fromt\ the document feeder to the scanner. One white molex connector with 2 thumb screws on back.
Lift the document feeder up and out, and lay it upside down on a table or work surface.
On the bottom side you will see a shiney white strip about 12 inches long and 2 inches wide, it has 2 holes, one on each end to access a couple of screws. Just remove it from one side, just held on with two sided tape. Then roll it back. Under there you will see I think 4 maybe 5 small black plastic rollers. They are held in with one screw attached to a small metal bracket. Remove the screws and plates for all the rollers, remove the rollers and take them off the shafts. Clean and very lightly lubricate those small metal shafts, and reinstall the rollers, etc. The white strip will stick back to the side you peeled it off of.
Those rollers are where the noise is coming from.
Jul 25, 2008 | Xerox WorkCentre M15i Laser Printer
Paper Feeder Jams
Use this link and when you call ask for Britt. I do NOT work there but I have used them for a long time and they are greart.
Here is the URL ..
https://www.partsdrop.com/store/
Jul 09, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Ink toner problem?
No, that is not the ink, That is a fuser problem.
The fuser needs to be replaced.
It is a very easy repacement. Cost is between 170-200 dollars if you don't have a service agreement.
One of the two rollers in the fuser has a problem and is not making good enough contact to fuse the image.
Jan 10, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox WorkCentre M15i Laser Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
