My acer speakers have a green pointy plug and a usb port. I cant get them to work should I plug them both in or only one?
    Sergeant:
  • 267 Answers
Try pluging the plug first try speakers. if it dont work remove plug and insert usb. try speakers. if this fails try both. it will not harm the unit if its wrong .
Posted on Nov 15, 2009
Cant get to play music without headphoes
Most modern computers come with internal speakers already installed, especially laptop computers.
These speakers may be sufficient if you are performing typical computer tasks, but when you play computer games, listen to music or watch movies on your computer, you may want louder and more vibrant sound.
You can achieve this by installing external speakers or headphones. These can be connected to your computer through the speaker or USB ports included on your computer.
Plug in the speakers or headphones.
If the speakers or headphones use a stereo plug, insert the plug into the speaker/headphone port normally located on the side or front of your computer.
This port is often color-coded green. If the equipment is connected using USB, locate a free USB port.
Some external speakers will also need to be plugged into a power outlet in the wall or your surge protector.
This may be all you need to do to get the speakers or headphones to work. If they do not, continue to the next step.
Open the audio settings on your computer.
From the Windows Start menu, open the Control Panel. Here you will find audio and sound settings.
Click the heading to see your sound and audio options.
Choose "Manage audio devices" in Windows 7.
Find your Playback device.
In the Playback tab, you can select your speakers and set them as the default for your system.
If you do not see your speakers or headphones, they have not been installed properly. Disconnect and reconnect them to see if it corrects the problem.
Configure your settings.
Select your device from the list and click "Configure" to test your settings.
You can adjust the volume by using the volume slider on your computer's task bar or using external controls on the speakers or headphones.
Install speakers
http://www.liutilities.com/how-to/install-speakers-to-a-computer/
Aug 05, 2013 | Acer Computers & Internet
Speaker will not work. Cannot adjust the volume.
Make sure you can see the small LED light on the speakers. If I remember correctly, those speakers are USB powered, and need to be plugged into the USB port for power, and the green audio output port for sound signal. If they are plugged in, and you cannot turn them on, you have broken speakers. If you CAN turn them on, then ensure that the audio cable is plugged into the green audio output jack (sometimes it has a headphone icon by it) and make sure your computer has not muted the audio.
May 17, 2010 | Dell A225 2 Speakers
I can't find how to plug my speaker to my computer. it's a set of only one speaker and it has an USB port, also a normal pointy connection. I've tried to plug them both everywhere but it doesn't seem to...
Hi there bud...Make sure you speakers calbe the Audio Jack (green labled) is connected into the green labled socket in your PC..also make sure you have audio drivers installed , and/or motherboard drivers ;)
Happy new year
Jan 11, 2010 | Acer (AV120) Computer Speakers
Have windows 7 on my new acer aspire 5517; trying to get external speakers (2 different kinds) to work. my generic usb speakers install and it shows they're working properly, but errors when trying to play...
what happens when you plug the speakers in the green port? You might want to try the other audio ports because on a few new computers i have seen the speakers have to be plugged in a different hole. also make sure the speakers are plugged up to the electric plug.
Dec 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
Get no sound out of speakers , what do i plug in? Green plug or usb plug
It is my understanding that the USb plug is to power the speakers and the green plug is the traditional plug to put into the sound card itself. Do you get sound if you plug it in like that?
Possibly the sound is muted or turned way down? Not trying to be a wise guy, just never hurts to check the simple things too
Sep 15, 2009 | Acer Audio Players & Recorders
2 SET OF SPEAKERS WON'T WORK FOR ACER E380
Do these speakers came with the system? If yes then check your manual from the Acer's website ( www.acer.com)
Also what color ports do you have in the back of the Desktop?
I believe you have a green, a Blue and a pink port, the Green is for outgoing sound, the Blue is for incoming sound, like a tape player recorder or a External CD player to get sound to your PC, and the PIN is the Microphone.
Feb 11, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Speakers
You will need a seperate audio cale with green plugs on both sides, 3.5mm jacks, one from the screen into the green port on your computer.
Jul 12, 2008 | Acer AL1912 19" LCD Monitor
Acer computer speakers
Speaker issue desktop's only
1. Plug USB into USB port (any)
2. Plug Black speak cable into LIGH GREEN (NOT BLACK) connector
3. You will see a popup window - make sure it is on Front Speaker out
4. Click OK - you will a cartoon computer with speakers on either side -then click on one of the
speakers to test
5. if that does not work then follow this:
Reinstalling apps:
1. If in Windows - Start - Programs - Acer Empowering Technology - Acer E-recovery management -
click on Restore at bottom then "Reinstall apps and drivers" - look for hardware drivers that you
need. Click "install now"
Jan 06, 2008 | Acer 90.00012.30B Computer Speakers
Speakers
speakers to test
Reinstalling apps:
Oct 05, 2007 | Acer 90.00012.30B Computer Speakers
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
