Question about Ryobi Garden
Whitch gas line from the bulb gos where - Ryobi Garden
  • 1,040 Answers
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Nov 27, 2009
  • Jim Parker
    Jim Parker Nov 30, 2009
    Did this solve the problem?
    Jim
Screen GO'S Black then the sound & tv go's off
check the door switch for the bulb, if it is not contacting with the switch the tv will turn off. it somtimes dont catch the switch when you put the door back on.
Mar 31, 2014 | DSMiller Inc Samsung Rpt50v24dx/sms 150...
Replacing the gas lines form the gas tank and the line to the bulb
on my husqvarna 125b the fuel line in the tank with the filter connects to the bottom of the carb. the other line coming out from the tank connects to the bottom port on the bulb. the line from the top port of the bulb connects to the top of carb. hope this will help.
Nov 24, 2012 | Garden
I have a Craftsman Weedwacker 25cc 358.791030 that won't start. Primer bulb is not getting gas. Gas line is connected to the filter resting at the bottom of the gas tank. The line for the primer bulb...
that line should be longer, it contains the filter which is the pick up, and should rest inside the tank fully,, see if its possible to pull that line farther into the tank, its not going to start until the primer bulb fills
Jul 24, 2011 | Craftsman Convertible 25cc. Gas Line...
When main burner comes on 20 secs later pilot gos out gas valve then shuts down
Remove the burner tray, Clean pilot orifice, make sure it is screwed in and in the right position, and replace the thermocouple. This should cost about $50-$75 and can be done by anybody.
The gas line will probably have to be undone temporarily to remove the burner tray. If it was installed correctly there will be a union on the gas line and this shouldnt take more than an hour once you have the new thermocouple.
May 03, 2011 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
NO GAS IN CARBURATOR BUT GAS GOING THROUGH PUMP AND COMING OUT FUEL LINE
sounds like old gas, n carb can use cleanin put wire through were ur gas line gos on ull will have take carb apart wire should come out were jets r wen apart make sure clean carb good with old cloth n gas if looks clean ennuff try it out
Apr 09, 2011 | Polaris ATV
Getting my new fuel lines in correctly from gas tank to priming bulb & from gas tank to carb.
on weedeaters,chain saws. most are the same.
line with little filter in gas tank goes to carb. line out of carb to primer bulb
line from primer bulb to gas tank
Jun 24, 2010 | Garden
Whitch sparke plug lead gos to what on my mazda 323 v6 1994 model because my dad ript them out now we do nt kont witch lead goes where
Sorry for the delayed response.
If you still need the information:
The 1994 Mazda 323 does not have a V6 in it, It is a 1.6L Linear 4-Cylinder.
Click on the following link:
http://autorepair.about.com/library/firing_orders/bl-fo-7384.htm
Again my apologies...
Let me know if this helped.
Jan 18, 2010 | 1994 Mazda 323
Whitch gas line from the bulb go's where
Nov 15, 2009 | Ryobi Garden
GAS LINE PROBLEM
Hi this is the way it should go: 1 from the filter in the tank to the bottom of the carby,2 from the top of the carby to the inlet on the primer,3 from the outlet on the primer back to the tank as this is the return line nothing goes onto it.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
53 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
