Question about LG Shine KE970 Cellular Phone
Lgecb630puk blocked down . fix - LG Shine KE970 Cellular Phone
Installing new carburetor. How do I fix the paper gasket between the block and the carb.
you dont fix in long run cheaper and easier to replace with new because if fix fails will have to retear down to do it again
Sep 11, 2016 | 2007 Ford Focus (3 Door) Hatchback
My 2007 sea do RXP won't shut off after the key is removed
Hello Lisa,
The most likely fix is for you to check the wires connected to the engine block and verify that they are not broken. There is 1 wire that connects to the engine block then goes to the key, then from the key to the ignition coil block. When the key is in the "on" position the switch is actually open allowing the engine to run. When the switch is in the "off" position it is actually closed and shorting out the ignition block and killing the spark generation, therefore shutting down the engine. So with a broken wire the engine will not shut down at all!!
Aug 02, 2016 | Sea-Doo US 2007 RXP 215
1993 Kobelco SK 60 Acera had an ignition issue that was fixed but now the machine runs fine for about 30 minutes then bogs down like it is starving for fuel. Any suggestions for a fix?
It sounds like there is a venting problem with the fuel tank. These tanks have a vent check valve at the top of the tank that normally lets in air as the fuel is being used but in earth working machines this vent becomes blocked from dust and blocks off
Aug 01, 2014 | Cars & Trucks
Will start but wont stay running
Most certainly take this back to the mechanic and have them fix this until they get it right.
Jan 29, 2014 | Chevrolet Venture Cars & Trucks
I don't know how to unblock zanga poker
this is a easy fix,go to facebook account setttings then to blocking scroll down you will see games that are blocked look for poker then just check unblock,then poker will load for you.
Jan 13, 2013 | Facebook Social Network
How much to fix a cracked block
Basically, you don't "fix" cracked blocks....you replace them.
Now, having said that, is this cracked block causing a loss of coolant?
If this is the problem, there are some block sealers on the market that do a commendable job. Thing is, if it works....great! If it doesn't...well, you didn't spend an arm and a leg for the sealer.
A product I've used with some success is Head Gasket Repair and Block Seal by Bar's Leaks. It'll run around $13.00 for a 20 oz. bottle. Check www.barsleaks.com for all their products.
Feb 06, 2011 | 2000 Chevrolet Blazer
Camera just drped down and not able to shut down
its mean you camera lens block not close.your camera lens adjustment out.you can fix it by open the lens block and readjust.for this you need to open your camera cover then remove Lens block by opening to wire.
Oct 21, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
The oil light comes on when i'm stopped and when i drive the oil light goes off however i opened the hood and i've notice on the side of the engine block i see oil moisture around the block and oil that...
The first thing to do is check the oil level and top it up and then check it quite often until you get the leak fixed.
To find the source of the leak, wipe the side of the engine down with a rag to clean off the excess oil. Start it and let it idle while you watch for oil to start coming out. Focus on the area where the oil stops. Occasinal reving the engine may help. I'd be looking at valve cover gaskets as the most likely cause., They are an easy back yard fix. Hope this helps.
Sep 18, 2010 | Ford Taurus Cars & Trucks
Phillips mx3660d dvd player with surround sound system overheats about 45 minutes into a movie and then shuts down. Once it cools down you can turn it back on and finish the movie. Does anyone know what is...
my phillips mx 3660D digital surround dvd system won't read the movies any more it says no disc.It will play music cd's beautifully ok whats the problem? help it was playing fine
Oct 18, 2009 | Philips Magnavox DVD/VCR Dual Player
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
LG Shine KE970 Cellular Phone Logo
55 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
