Question about HP Computers & Internet
How do i get a copy of the reboot disk for hp dv 5000my computer well not advance pass the setup screen
    Genius:
  • 1,752 Answers
Contact HP, they'll be happy to sell you one.
Posted on Nov 15, 2009
Error message on dv 1000 pxe-mof and pxe-e61
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 17, 2013 | HP Pavilion dv1000 Notebook
My hp pavilion dv6 laptop startup process, every other process even media player also very slow speed is working . how can i solve this kind of problem?
1) you NEED tune up your computer.Normally the computer has integrated the software for solution and get integrated the software diagnostics, and TUNE UP use it.
2) uninstalled programs
3) clean for cookies,etc
4)updated your computer from window
5) pass the AntiViurs +Malware software
6) pass the Check disk from your local disk, etc
Try it , otherwise you must go to the repair shop computer for fix it.
Sep 25, 2012 | HEWLETT-PACKARD HP Pavilion DV-61053CL...
Cannot install windows 7 on hp media center (m8307c) computer. Using OEM windows 7. Says windows cannot install on computer hardware. Using 1.5 tb wdc replacing 500 gb wdc. HP has given up.
Try installing windows by booting from cd, restart your computer and while its starting up press the del button (there's usually a prompt to do so on the bottom of the screen), you will be taken to a bios setup screen. In this setup you can not use the mouse so use the keyboard to navigate to the "Advanced Bios Features" option, go down to "First Boot Device" press Enter key then select CDROM, press F10 to save then exit and restart the computer with the Windows 7 disk inserted, after a bit it should prompt you to press any key to boot from disk so press any key and your windows installation should begin.
May 03, 2011 | Computers & Internet
I have a hp p6203w how do I enter bios
"HP
Pavilion:
Method 1
Enter the BIOS: Press F1 during the blue HP screen for setup.
In the BIOS: Advanced to Peripheral Configuration to Parallel Port Mode. Use ENTER key to open menu and select EPP. Press F10 to save changes and exit.
Method 2
Enter the BIOS: Press F1 during the HP boot-up screen for setup.
In the BIOS: Advanced to I/O Device Configuration to Parallel Port Mode. Use ENTER key to select EPP. Press F10 to save the changes and exit."
source: http://www.easeus.com/disk-copy/faq1.htm
Apr 08, 2011 | Computers & Internet
I have an HP dv6700 that won't boot windows. It's running vista 32 bit with Phoenix bios on there. I have tried a recovery disk but there seem to be no startup errors nor did it find memory nor hard drive...
BIOS diags do not test RAM's Windows functionality. Download Microsoft's Memory diagnostic too and burn to a cd. then test your memory.
To run Windows Memory Diagnostic, you must reboot your computer with the disk or CD-ROM on which you installed Windows Memory Diagnostic in the drive. After the reboot, Windows Memory Diagnostic will load and its interface will appear. After loading, the first test pass will begin, using the default standard test suite, and continue until complete, unless Windows Memory Diagnostic is either paused or exited. Once the first test pass is complete, Windows Memory Diagnostic will begin a second test pass using the same settings as before. Windows Memory Diagnostic will continue to run test passes until you exit.
http://oca.microsoft.com/en/windiag.asp
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 21, 2011 | HP Pavilion DV6700T Notebook
I recievced a dell pc desktop dont know what model it is but its set up for a corp network. cant get pass password would like to wipe drive and install xp have disks. how do i go about this. i think its...
The model name, and model number is usually on the back of the computer tower, next to the Windows Product key, or up on the side of the computer tower case.
Sometimes you have to open a door on the Front Panel, and it is located inside. (Not on the door. On the computer. The Front Panel is the plastic front of your computer)
You have XP Installation disk/s?
You are aware that Microsoft's User's License states,
"Only one genuine copy of Windows per one computer"
(Microsoft makes a Master disk of an Operating System. The copies made from it are bought by the consumer. These are GENUINE copies)
If the Windows XP installation disk you have is a fresh disk, I suggest you go to BIOS Setup, and in Boot Options change the first boot option to CDROM.
Windows doesn't 'like' having the same operating system installed over it.
Making sure that your optical drive, (CD or DVD. Player or burner, doesn't matter), is the first boot device, will override the above.
How to get into BIOS Setup for a Dell? (It's actually BIOS Setup utility)
Dell uses different keys on the keyboard for their different models.
A) The Dimension models usually use either the DELete key, or the F2 key.
B) The Inspiron models use the F2 key
C) The Latitude models (Desktop computer) use the F2 key
D) The Optiplex models may use either the F2 key, or the DELete key.
E) The Precision models use the F2 key.
Computer off, right after you press the Power On button, start tapping, (In 2 second intervals), on the appropriate key for your Dell model.
Note that I stated two different keys for some of the above models.
The procedure to find out which is the correct one, is to simply try one that is listed, and if it doesn't work, try the other one.
HOWEVER, you try using the first key.
Doesn't work?
Then you need to start all over.
You need to reboot the computer. (Restart)
Press the CTRL, ALT, and DELete keys at the SAME TIME.
This will restart, (Reboot), the computer, where you can try the other key.
Once you are in the BIOS Setup utility, you need to look for Boot Options.
There are many types of BIOS setup utilities, and Dell didn't/doesn't use just one.
You may see Boot Options in the top header of the BIOS Setup utility.
You may not.
If it isn't listed at the top, scroll down to the listing similar to,
Advanced BIOS Options, and open it.
[In the BIOS Setup utility you can no longer use your mouse.
You will use the Up/Down Arrow keys to highlight the area you wish to open, and then press the Enter key]
For questions please post in a Comment.
Sep 18, 2010 | Computers & Internet
Need a recovery disc for Pavilion dv-5 notebook
Hi:
You most likely have a bad hard drive, and a disk set is not going to help you, though you will need it too.
What you need is a new hard drive, a copy of all the drivers for your laptop, which you can download for free from HP. If HP won't send you a copy of the recovery disk, you can use any OEM copy of the same operating system that your laptop has a sticker for, but you won't have all of your programs.
Nov 23, 2009 | HP Pavilion dv5-1140us Notebook PC
I got a laptop of a friend and i want to rebbot it because they never gave me the user name password or a disk..How can i reboot it to the factory setting?
HP laptop don't come with recovery CD's they have a hidden recovery partition on them.
To access the partition turn on the computer. When the initial blue HP screen appears Press the "F10" key. A Recovery menu will appear. Click on "NEXT" and then click on "YES" Your system will now go through the product recovery.
Good luck
Aug 14, 2009 | HP Pavilion dv5-1251nr Notebook
Computer is stuck on welcome screen
The file system (rather than the physical data) may be damaged on the HD. Try this:
1) Boot the computer using a Windows XP setup disk. (It doesn't matter if it's Home or Pro or what Service Pack. A Win 2000 setup disk should also work.)
2) At the first screen where you can respond, hit R to enter the Recovery Console. ***make sure it is RECOVERY not REPAIR***
3) At the command prompt you will get, type the command CHKDSK /P
When CHKDSK is finished running (it may take a LONG while), type EXIT and reboot from the HD. Windows just may start OK. **** DONOT reboot or power off untill it completes. Make sure it has mains power connected so batteries cannot go flat***
Jul 14, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
