Question about Maytag Neptune MDE5500AY Electric Dryer
My dryer arm inside the drum has come loose. How can I get to the inner part to put a new screw and tighten others?
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, Remove the drum,and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
Now you can repair your dryer arm.
Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 15, 2009
Inside the drum one of the tumblers is loose how do you tighten it up?
You can tighten those baffles by getting to outside of drum to thighten the screws that hold them to drum. to get access to outside of drum;
Remove screws from door hinge
remove screws from other side of inside door as they are exaclty opposite the ones for hinges
pull off from panel by putting putty knife/screwdriver in seam between front panel/cabinet just below the sloped part of the top and pop off front panel
in the upper corners of the top/front panel is a clip that looks likea inverted "7" or if ya will a up side down "L" remove screws from the clips and remove the clip
now ya can raise top to get to outside of drum
rotate drum by hand in CLOCKWISE direction to turn drum so ya can get to each baffle
Thanks for using FixYa.com,
Gene
Aug 22, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Inside the dryer there are 3 bars that stick out to help tumble the clothes. One of them has come loose and I'm not sure how to tighten it. It appears to be attached with screws that come thru the drum...
With the front off look up in the top left and right corners for some screws that hold the top of the dryer to the side panels. Depending on your model, there can be different styles. The old maytags used 3/8 in screws up inside the corners and the newer models had 5/16 screws right up front.
Once you get the front of the top loose you will be able to lift it like the hood on a car to gain access to the drum.
Rotate the drum by hand to put your loose fin at the top and tighten up your screws. Sometimes the screws will round out the holes on the drum too much and you may want to put a washer on the screw to secure it better.
Oct 07, 2010 | Maytag Dryers
Fin inside dryer drum loose and rattles can it be
get to out side of drum and tighten screws
Apr 25, 2010 | Dryers
I HAVE A MAYTAG NEPTUNE DRYER. THE RIB ON THE
remove the toe kick front panel screws near the floor in front then lift up like a car hood to release clips at the top,then remove screws that hold top on,then you can get to the baffle screws to re attach
Jan 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The drum will not turn when you start the dryer. The belt will need to be exchanged but how can I access the belt?
You have to open the cabinet and remove the front. Some have screws through the front, others have the screws on the inside that are accessed after raising the lid. To open the top slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. If you don’t see the screws on the outside, they on each side on the inside holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on. If there isn’t an opening on the back to access the motor pulley, you have to reach under the drum from the front to thread the belt onto the motor pulley. When putting the front panel back on you need to guide the drum and the front panel together at the felt seal around the door opening. Vacuum the cabinet well while it is open and make certain to unplug the power cord and turn the gas off if applicable.
Jun 07, 2009 | LG DLG3788W Gas Dryer
Maytag neptune model MDE5500AYW loose tumbler in drum
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick pull. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loose screws or other,need to enter dryer drum to remove objects...our model is MD5500...does top come off first or front first???? phone # 303-221-0550 or email jerrydhayes@hotmail.com The NOISE is very...
Mar 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
FIn inside neptune md55 dryer came loose need to remove side pane
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick ****. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My neptune dryer sounds like screws are tumbling, one of the 3 dividers connected to the drum inside the dryer is loose and it is leaving black marks on clothes
Hello
Welcome to Fixya
My name is Huum,
You said, my Neptune dryer sounds like screws are tumbling, one of the 3 dividers connected to the drum inside the dryer is loose and it is leaving black marks on clothes
Those are the screws that hold the dividers to the drum.
The drum ha to come off to replace them. Big job!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
214 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
