Question about Microsoft Windows Vista Ultimate Edition
Installed windows vista and can only get a resolution of 640 x 480 pixels. my graphics card is a STANDARD VGA GRAPHICS ADAPTER. any help or addvice appreciated
    Guru:
  • 597 Answers
Stardard VGA Graphics Adapter is what the driver Vista installs when it doesn't have the right driver for your video card. That isn't your video card type. You need to check out the documents for your specific computer and find out what kind of card it really has and download the driver for that card. You will then be able to choose a higher resolution. Sometimes when you boot up your computer and the screen first comes on it will tell you what type of video card you have but this only works on some models.
Posted on Nov 15, 2009
Testimonial: "thank you for the info."
  • 187 Answers
I don't know what you have already tried, so here's a list: You may be able to go to Microsoft update and choose optional software that includes device drivers. It will tell you what is available on the left menu. Or, go to Control panel, display, settings, and click the advanced button. Click on ADAPTER and then drivers tab. Search for a new driver. Allow choose automatically from the internet. If the adapter isn't on the tab or it says it can't find a better driver, you will need to find out what kind of card you really have. It's not "standard," that's the problem. Your graphics card can be identified by going to Start, Accessories, System Tools, System Information. Click the + next to components. Go to display.Look to the right and you will see what kind of of adapters you actually have.
If you can't find the driver by MS update, you can go to the company of the website that makes the driver. I don't recommend a general search. "Free driver" sites are not always safe. Lastly, sometimes you can use add new hardware in the control panel, or start your computer with the monitor unplugged. Then turn the computer off, and restart with the monitor plugged in. The device manager will sometimes load it correctly. If you want to know how to uninstall it from device manager, ask that question. It has it risks and can't be fully described in space here.
I installed windows 7 but my vga(via p4m266a) doesn't support how can i fix it
Hello if it is this mainboard:
http://www.asrock.com/mb/VIA/M266A/?cat=Download
It`s to old to run windows 7 with the onboard graphic.
And the driver does not supports windows 7.
You can add a new graphic card in the agp 4X
socket on the mainboard.
Just make sure the graphic card driver supports windows 7.
Good luck
Dec 05, 2012 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Can't play games after windows 7 install
Have you installed the latest drivers for your video card ? Because in your description you are running with standard VGA drivers from operating sistem. Find your laptop model and visit the manufacturer support site and see if they have driver for Windows 7. If not try to use Windows update from Operating Sistem, from Start menu - Applications - Windows Update.
Apr 10, 2010 | Microsoft Computers & Internet
Not starting in normal mode only black screen but good in safe mode help pls
In safe mode you are using standard low resolution VGA graphic option that is why it would work: Re-install the graphic adapter driver and/or set a different graphic resolution: I suggest starting with 800 X 600 and default or 50 or 60 Hz frequency as good starting points.
Hope it helps! let me know how you go!
Dec 30, 2009 | Microsoft Windows Vista Home Premium with...
Resolution issues since vista upgrade
Just force and install the driver, It should be working good. I too had similar problem. I just forced and installed the driver even though it said that its not compatible.
Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
Resolution goes back to 800X600X75 sva 20" LCD
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | SVA-USA Computers & Internet
Problem with Standard VGA Graphics Adapter
You need to install the drivers for the graphics card that you have. Search for the drivers on toshibas website.
Jun 24, 2009 | Toshiba VGA Board Graphic Card
My monitor requires a resolution of 1360 x 768 but I can't change it in Windows Xp eu but I could before with others versions of windows
The allowed resolution does not depend on the Operative windows used (XP,Vista, etc.) , but on the video adapter installed on the computer and on the video card driver.
If resolution 1360 x 768 was supported before on the SAME computer with a different system, then you may need to re-install the video card driver.
If resolution 1360 x 768 was not present before on same computer, then the display adapter installed on this computer may not support 1360 x 768.
Check specifications on Google, download updated display drivers, and if nothing works, then buy and fit inside the computer display adapter supporting 1360 x 768, like the one here: e-GeForce 7200 GS TC 128 MB PCI-e Graphics Card
Apr 01, 2009 | LG W1941S-PF Monitor
Vista to xp
To have the best resolution for vista, you have to have a directX-capable graphics card and a min of 128MB of graphics memory. Check if your vga has windows display driver model and hardware pixel shader 2.0 support
Oct 21, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Druid..
The standard VGA adapter comes automatically with the OS. You can try one thing...Go to device manager, find the entry for the Radeon card, and delete it. Next, shut down the PC and then restart the machine. The OS will automatically find and install the appropriate driver.
May 11, 2008 | ATI Mobility RADEON Graphic Card
Acer al2016w monitor
when you say you have it plugged into the on-board video output.. does that mean there is a graphics card installed too? used to be graphics card installed? if there is or was then its possible that there is a bois setting that tells your computer to use the existent or non-existent graphics card. either was your onboard is going to shut down. This is one theory.. but since its is turning off once you get to your desk top the more likely reason is that its software based and you either have the wrong resolution, driver, or refresh rate selected to use when windows boots. Toy around with diffrent resolutions, refresh rates, also if you have a graphics card plug it into that. your on board most certinly will not be enabled if you have a graphics card.
VGA MODE in vista:
Restart the computer and immediately start pressing the F8 key, once per second. At the selection screen, use the up/down keys to select "Enable VGA Mode", then press the "Enter" key.. If it works, it will bring up the basic VGA drivers in "normal" Windows and should allow you to install the Vista compatible drivers for your new card. After installing the new drivers, restart the computer and if it remains in VGA, you should then be able to adjust the resolution, etc. from the "Display Properties".
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
Microsoft Windows Vista Ultimate Edition Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
