Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My Crafstman garage opener is melting my light bulbs!
My Craftsman opener is 9 years old and this problem started about 5 years ago. I have tried regular 60W bulbs and energy efficient bulbs, but the same problem occurs. After 2 months of use, the bulbs begin flickering on and off when I open the garage door. Eventually they stay off. I initially thought these bulbs were burning out prematurely, but after I inspected the bulbs, I discovered the conductive tips on the very end of the bulbs that go into the sockets are burned through. Any ideas on another bulb that will not get "melted"?
  • carothe Nov 15, 2009
    Re: my post above, I found a possible reason why the soldered ends (or contacts) of the bulbs in my opener are melting. The contacts are not making good contact with the metal tabs in the bottom of each socket, causing "arcing". I figured this out after reading about this problem here:http://www.askthebuilder.com/EM0017_Ligh...
    I shut the power off and bent the tabs in the sockets so they make better contact with the bulbs. We'll see if this works.
    President:
  • 3,197 Answers
Rather than new bulbs I suggest you unplug the unit and use a small screwdriver to pull out on the center contact of the light socket.
Posted on Nov 15, 2009
My crafstman garage door opener goes down and then
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear and is probably stripped.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remove the cover and check the drive gear. It could be stripped.
Mar 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Blowing out light bulbs
There are rough service bulbs you can buy at hardware stores. You can also try unplugging the unit and using a small screwdriver pull out on the center contact in the light bulb socket.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 HP Craftsman Garage Door Opener works but lights don't
I think you are saying that normal incandescent bulbs do not work. If that is correct you should unplug the unit and using a small screwdriver reach into the socket and pull out slightly on the center contact.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Old 1/3 hp sears craftsman garage door opener
There is no way to defeat that timer. It is programmed into an integrated circuit on the logic board.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor moves 5 in" and reverses and light blinks 5 times
In the manual it says if you can hold the wall button down & door closes. You have a short in the wiring to the reciever eye. Try substituting some new bell wire in its place, or test the wires for continuity.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light bulbs burn out after a few days in garage door opener, craftsman 1/2 HP double lights. have used every kind out there, specially made for garage doors, etc.
Try REVEAL brand DOUBLE LIFE ceiling fan light bulbs, available from HOME DEPOT. The filament in those bulbs is much thicker than any others, and the one I installed on my own Sears GDO has lasted 3 months so far, compared to one week for others I have tried.
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
431 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
