Question about Kenmore Sewing Machines
I have a Sears Kenmore 1430 and am having trouble with the bobbin. It keeps bunching up and I am unable to corret the problem. Thanks for any help you can give me.
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
mohammed387
  • 1952 Answers
SOURCE: bobbin thread keeps breaking and bunching up
check ur bobbin holder
Posted on Dec 11, 2008
SOURCE: Bunched bobbin thread
Try changing the needle. If you're using the wrong needle for the type of fabric, this could happen.
Posted on Mar 25, 2009
  • 30 Answers
SOURCE: mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Posted on Aug 22, 2009
  • 32 Answers
SOURCE: Owner's manual
I found a website for you that might help. They have a lot of kenmore manuals including one similiar to your model#148.12051. The manual opened as model 1205 so maybe searching for your model as the 1201 might help too. hope this helps! =)
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/kenmore_sewing_machine_product_list.html
Posted on Feb 04, 2010
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
I have the Kenmore sewing machine #16231. When I was sewing the bobbin holder popped out and a bunch of thread bunched together and wrapped around the bobbin and caused bunching of thread on my fabric...
Bunching of thread is 99% a top tension problem. Make sure you thread the top thread correctly. Thread the machine with the presser lever up. Test the tension by lowering the presser lever before threading the eye of the needle, by pulling the thread with your left hand and adjusting the tension with your right hand while slowly pulling downwards. There should be no resistance when the tension dial is on zero, and you should be able to feel more resistance when you increase the tension. Ideal tension is between 3 and 5. When your top tension is correct, your machine should operate correctly. If you feel no resistance with the presser foot down and the tension dial on 5, check the tension disks for fluff or broken thread. When you lift the presser foot, the tension disks should open and you would be able to remove any cotton or fluff. Good Luck
Sep 01, 2011 | Kenmore Drop-In Bobbin 16231 Mechanical...
I can only sew a few good stitches and then it starts bunching up underneath the fabric. I have watched the top and bottom thread as it goes around the bobbin case. After a couple of stitches it seems to...
It very well could have a burr in on your bobbin case, If, it was me, I would take it to Sears sewing machine department and ask them what they think it could be. They sometimes have new bobbin cases right there for you to buy, depending how big your Sears is. It won't cost you anything, at least to find out from the saleman.
Jan 19, 2011 | Kenmore Sewing Machines
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Jul 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Brother LS2020 Unable to sew because bobbin locks up
Okay I think i can help- i have mastered the lower bobbin threading after 4 hours and am now trying to sew but thread keeps bunching up. Anyway you have to line finger of boobin in the top notch, this will keep your bobbin from getting stuck. Hope i helped Lesnbek
Jan 13, 2009 | Brother LS2020 Sewing Machine
Thread is bunching up around the bobbin casing
On the bobbin case is a small screw if it is to loose the thread won't feed like it should make sure that screw is tight but not so tight you can't get the thread through it. Also check to make sure you have threaded the top right. hope that helps
Oct 14, 2008 | Kenmore 15208 Mechanical Sewing Machine
Bobbin thread bunching
I have a Singer 2950. The thread keeps getting bunched up on the reserve side of the fabric, and does not stitch. It is driving me crazy. I think I have the bobbin threaded correctly, as well as the machine. I have tried everything! Please help!
Oct 22, 2007 | Sewing Machines
Sewing Machines Logo
54 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
