Question about Craftsman Garden
Sears Craftsman model 917.270.711 (10 years old). This is a followup question. The mower had been starting roughly with white smoke. It got progressively worse, to the point where the mower stalled with large amounts of white smoke (seemed to happen after engaging blades, coincidence?). Gas definitely had entered the oil crankcase. I inspected the float and needle valve- they look OK.. Other than the carburetor, are there other things I should be looking at? Thanks.
  • 486 Answers
There is a possibility that the head gasket is blown.
Until you are certain the issue of fuel being in the oil is resolved, internal engine damage could be happening. Inlet needle/seat leakage must be check with a leak detector or pressure guauge.
Posted on Nov 16, 2009
Where can I find the model number on my Sears riding lawn mower? It is about 6 or so years old.
Sears puts the model numbers under the seat on most machines since 1990. They are in the format
xxx.xxxxxx
example 538.678567
Good luck
Mar 28, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a 17 year old snowblower. Sears Craftsman 3 HP single stage. It wouldn't start. I changed the spark plug and now it started but it's running very rough with excess smoke. If I press the gas...
Good to hear you got it running anyway.
Look for a choke, maybe it's just running with the choke set. Could also be that it's all gummed up from sitting, if that is the case then some running should bring it out of it by the time you've put a couple of tanks of fuel through it.
Is this a two-stroke motor? If so, be sure you have your fuel mixed correctly- go by the manufacturer's statement concerning how much oil to how much fuel, never assume that the oil bottle directions apply to your machine because they probably don't.
Good luck with it,
lp
Dec 28, 2010 | Craftsman Garden
Mower suddenly shut off and engine starting smoking. Now it won't do anything. seems to be locked up. Sears craftsman riding mower only 1 and a half years old. has oil and gas.
About the first thing I would do is to pull the plug lead(s), tilt the mower up (resting it on something solid) and see if the motor shaft could be turned at all. I suspect you initial thought that it is locked up is correct.
May 15, 2010 | Craftsman Replacement Belt for 42" Deck
I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
Nov 07, 2009 | Craftsman Garden
Craftsman lawn tractor, model 917.270711, smoking and stalling
That is a Briggs & Stratton engine and given its age, I would say it is time to overhaul or replace the carburetor. Over time the float needle and seat become worn and inoperable which is why you are getting fuel in your crankcase. If you are not familiar or comfortable with working on these things, this is a job better left to a professional. There are too many things that can (AND WILL) go wrong in trying to do it yourself. Just scan through some of the questions on here and see how many others have taken theirs apart and can't remember how to put it back correctly!
Oct 11, 2009 | Garden
Smoking Craftsman Riding Mower
1st thing, check your dipstick up inside the cap part of it and make sure the O'ring is there and in good condition.
2nd, make certain when you put it back on that you get it on straight and firmly seated. They will only seat one way properly the other way creates a leak into the crankcase and causes oil consumption and smoking. You should be able to tell if it has been improperly installed by an excessive amount of oily dirt accumulated around the threaded area of the cap
Sep 15, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Garden Logo
400 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
