Question about Frigidaire PLGFZ397G Kitchen Range
Frgidaire Pro series gas range not lighting on one burner
I have a Frgidaire Pro series gas range that is about 1 year old. The front left burner does not spark to light. Gas flow is fine to all. All the other burners spark and light just fine. Do I need to replace something or clean something or ? How do I lift that top off to look?
  • 460 Answers
There is probably some residue keeping it from sparking. look at 1 of the other burners and take mental note from where the spark is coming from. then spray just a little oven cleaner on and around the one not working. naturally take the metal grid off first.. let set for about 15 min. then wipe away the residue gently as not to damage the igniter electrode.. also there is a possibility the wire leading to the igniter fell off causing this problem.. do the explained first. good luck...
Posted on Nov 15, 2009
Grill burners not working correctly. There are 3 burners under our grill. the left one has pilot light on but wont light burner middle and left burners will only work if turned clear up to high
Not familiar with these models, but it sounds to me like it could be a gas pressure problem...? Is there a regulator - sometimes they fail. Are any other appliances hooked into the same gas line? If so, how well are they functioning?
Jan 19, 2014 | Garland/Us Range Gfe60-4g36rr Gfe Starfire...
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool gas cooktop will only spark on left front burner
i made this video to help you troubleshoot kitchenaid and whirlpool cooktops
Apr 01, 2010 | Whirlpool GLT3615 Gas Cooktop
Ge gas range about 7 years old delay in lighting
take burner cap off and clean all the gas ports with paper clip etc.it sounds like the gas is not reaching the spark.usually clogged with grease or soap.hope this helps .please rate my answer :)
Dec 08, 2009 | GE Cooktops
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Mar 12, 2009 | Wolf Manufacturing Gas Kitchen Range
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire PLGFZ397G Kitchen Range Logo
127 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
