Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm WM2044CW - Washes poorly. Have traced problem to inadequate water supply. Have checked input filters for blockage. Wonder if water pressure might be low and it is filling by timer rather than volume? All is fine when I add additional water. Can it be adjusted?
  • 460 Answers
You would have to consult your users manual for that answer but, i would say yes there is...
Posted on Nov 15, 2009
What does error code ie indicate?
IE error mostly means not filling completely with water or very slow fill
Jan 31, 2016 | LG WM2688HWM TROMM SteamWasher
My ifb dishwasher show F5 and could not complete it's cycle
If your IFB dishwasher is a Neptune DX model, Error code F5 according to the owners manual is "Inadequate water supply"
F5
Inadequate water supply • Make sure the water input tap is totally open and that there is no water cut.
• Close the water input tap, separate the water input hose from the tap and clean the filter at
the connection end of the hose.
• Restart your machine, contact the service if the error resumes.
Oct 01, 2015 | Dishwashers
ERROR CODE 1e
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
You may try the following link, too http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
Sep 19, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Have a LG Tromm wm2688hnm and it washes fine and the drum is empty of water after a cycle. When I come back to wash another load a day or two later there is water that has pooled in the drum. I have had...
Sounds like you have a minor blockage in your filter. There should be a access panel to the filter. If you have your manual it should be located in there as to where exactly the access point is. The timing seems to be just about right for a blockage. The only other thing that is possible is that a seal has busted and is letting water drip down from the water hoses in the back. If you look at the filter and there isn't a blockage then try and shut of the water from the back when you are done doing a load. When you come back and no water you now know your starting to issolate the issue. Please let me know what you find. Hope it helps out.
Dec 22, 2010 | LG WM1814CW Front Load Washer
Getting f 20 error
F-20 error code for the Whirlpool washing machine is indication of inadequate water supply.
Check both hot and cold water supply lines to make sure machine gets enough water intake.
Also check the filter in the hoses for blockage
Nov 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Getting the OE error message on LG Tromm
Lg tromm wm2277hs stops when it gets to the rinse cycle...OE error code? washes, won't drain, won't rinse
hi
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Check pressure switch operation
  • Check flow meter operation
Jul 24, 2009 | LG Washing Machines
My Tromm washer blinks an OE message, the door will open, but the wash won't finish and there is water still in the washer. Please help
OE error means the water hasn't pumped out. 1st you need to check the filter behind the flap in the bottom corner. This may be blocked a check your outlet hose where it goes into the somethimes they get blocked there sometimes. When the filters out get a torch and shine it into the hole where the filter came from to see if theres a blockage in there. If all is clear will prob require a new pump.
Dec 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg washing machine error code is ie
IE = inlet error. Washer has not detected enough water after 8 minute fill time. Check screen at inlet water valves where hoses connect to machine for blockage. Look for kinked hose(s). Make sure there is water supply reaching machine. If all OK, most likely next thing is the water valve itself.
Sep 02, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
257 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
