Question about Boating
I need to replace the prop seal on a 1987 50hp evinrude
  • 3 Answers
You need to disassemble your gear case, remove the prop shaft, and then replace the seals. however, if you are careful, it is possible to hook them out with a screwdriver and reinstall them but you need to be carefull not to damage the prop shaft . if you do the new seals will leak. also be sure to put some sealer around the outside of the seals before installing them and a little bit of grease on the inside lips.
Posted on Nov 22, 2009
Water in oil in yamaha out board when old oil was drained no sign of water in oil after changing with new oil now water in oil
You need to replace all the lower seals and o-rings to the prop. I am having this done on a 2014 Mercury 60hp under warranty. Just the luck of the draw. I had a 1986 Evinrude for 6 years with no problems.
May 16, 2017 | Yamaha Motorcycles
I have a 1994 evinrude model be115tlerc it has a 3 blade prop,i want to switch to a 4 blade prop ,i need to know which one to order
check with your local marine dealer . when I worked for one back then they had no 4 bladed props for a 115 hp motor . only for 150 or bigger
Mar 13, 2016 | Cars & Trucks
Evinrude troubleshooting
check lower unit oil if ok . pull prop off see if it has a wod of string around the input shaft behind prop sounds to me its in a bind
Nov 19, 2013 | Boating
9.9 evinrude engine doesn't plane when in full throttle it just revs really high and doesn't go any faster? any tips?
Yes.Between your prop shaft and the prop is a rubber bush inside the prop.Its there to stop major damage to the entire driveline if you hit something.Its needing replacement.Most prop shops are cheaper then a dealer or you can go to an outboard wrecker and get a replacement.Its the prop bush and it will fix your problem.Hope this helps
Jun 22, 2010 | Boating
Water is getting into gear oil, lower end. I know what the problem is, I just want to know if I can do the work myself. I am a 58 year old drummer and I don''t have a lot of money. I phoned Klaus Marine,...
there is more than 1 way water can get in sad to say and with out a pressure test you might fix it and fix it and fix it again .400 sounds steep to me it might be shift rod seal or drive shaft seal or prop seal.or a combination of all three.check for fishline around prop shaft first .
Apr 23, 2010 | Boating
Gear oil creamy
It is that color because it has water in it. Good thing you found this out. You must have a bad seal on the prop shaft or the housing is cracked. This will happen if it got frozen with water in it. Hope this helps you
Oct 12, 2009 | Boating
Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Jun 15, 2009 | Boating
72 evinrude leaking lower unit oil out of the prop
Yes it you hit the nail on the head buy a lower unit seal kit for your make and model.
terry10
Jun 06, 2009 | Boating
Need online repair manual for evinrude 50hp outboard
how can I adjust the shifting linkage on my 50hp evinrude. I have the cable adjusted all the way out but it will not go into reverse
May 10, 2009 | Boating
Boating Logo
217 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
