Question about Casio Pathfinder PAG60-1AV Watch
Casio pathfinder watch model 1570 pat-60
Trying to find a gasket for it.
5 Suggested Answers
  • 73 Answers
SOURCE: Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
Posted on Jan 07, 2008
Techjoel
  • 79 Answers
SOURCE: Am looking for a users guide for module 3070 casio pathfinder watch.
Here's thre link to youtr manual.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3070.pdf
Good luck
Techjoel
Posted on May 16, 2009
  • 2501 Answers
SOURCE: users guide for casio watch pathfinder model pas 4108
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Posted on Feb 08, 2010
  • 2501 Answers
SOURCE: I just purchased a casio pathfinder watch without
If you haven't got instructions on how to do this, you can get
watches;
Accept terms
Posted on Jun 15, 2010
I have replace the batteries and after assembled the mode and adjust buttons are not functional.
I've had the same problem with another Casio watch and in my case I didn't place the inner parts of the watch exactly right. This must be done very precisely, otherwise one or more button functions don't work. Maybe it is worth a try to check the alignment of the inner parts of the watch.
Mar 15, 2015 | Casio Watch Sea Pathfinder Spf-60-1aver...
Set casio pathfinder watch
try this site:
http://www.ehow.com/how_5214673_operate-casio-pathfinder-watch.html
Nov 12, 2014 | Casio Pathfinder PAG80-1V Watch
Casio sea pathfinder sp60d reset
You need to open the watch and cortocircuit 2 points into the watch machine.
TicTacArea.com is Officla Casio Dealer
Casio Watches
Aug 19, 2014 | Casio Sea Pathfinder Triple Sensor SPF-60
Casio paw1300
This means that the back cover is not correctly closed.Reopen,check if gasket(important),springs,inner covers etc. are correctly in place,close and screw in carefully.
Feb 06, 2013 | Casio Pathfinder PAW1300-1V Watch
Casio PAW-1200T Tough Solar Pathfinder watch says OPEN. Watch has never been opened, and solar battery has full charge. Nothing works but the basic time and the light.
so here is the fix if you get op en display on your casio pathfinder or whatever model. mine happens to be a paw 1200t
1. you gotta break it open 2 pins each side band comes off.
2. pry off the side pieces. this exposes 4 screws.
3. the base then comes off be careful of the gasket.
4. once inside. notice a round circular object on the base and a small oval shiny gold copper piece.
5. For whatever reason the shiny copper piece has shifted and does not make contact with the tiny little springs there are 2 if you shift the base to make contact with the gold piece the op en goes away and watch is back to normal.
6. the fix is move this little piece back to where it belongs. i got lucky and the glue still held when i firmly moved it to its original location. super glue came to mind if it wont stay where it belongs.
7. gasket orientation and cleaning out the gasket channel is a given i used welding tip cleaners to do the intricate work. under the bands are very grungy. mine is about 5-6 years old. reassemble the way it came out.
if your battery is good and you get this op en look to your display for whatever reason this worked for me and if casio uses this as a warranty or warning of water coming in your watch it was a STUPID DUMB IDEA. those springs should be solid state and the watch is useless until it is fixed no light, no baro, no alt, no comp. notta and no buttons work. there is no reason whatsoever that this shiny copper thing shifts but it happened to me and my watch is working and my battery has had H or full power since day one.
Apr 11, 2011 | Casio Triple Sensor Pathfinder PRG60-1AV...
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    I just purchased a casio pathfinder watch without a instruction manual model PAW1500T-7V how do I find one
    watches;
    Accept terms
    Jun 15, 2010 | Casio PAW1500T-7V Atomic Solar Pathfinder...
    I have a Casio Pathfinder PAG-70 that reads "OPEN" on the display where the date should be. It is a solar powered watch and shouldn't need a battery change. Any ideas?
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
    Mar 15, 2010 | Casio PRG-40T-7 Pathfinder
    Help Me set the watch please
    http://world.casio.com/wat/download/en/manual/
    Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
    Hope this tip helps.
    R/
    David
    Dec 21, 2009 | Casio Pathfinder Watch with Hunting Timer
    Casio Pathfinder PAG60-1AV Watch Logo
    429 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
