Question about HP Compaq Presario CQ60-249US Notebook
Compaq Presario CQ60-249 US Notebok PC: I left the notebook on for 10 hours on sleep mode. while I was asleep. When I woke up, I tried to move the mousepad to make it exit sleep mode but no response. So I pressed the power button so I can quickly turn it off to give it time to cool off. About three hours later, I turned it on but nothing was shown on the screen and I still hear the fan even though the notebook is completely cooled off. I waited until the next day to turn it on, but the same thing happen. I have warranty available still but I wonder if there is something I can do about it before I have to resort to using the warranty.
  • 813 Answers
In case it is in warranty, so not try to repair it as it may void the warranty. It is better to take it to a service center. Moreover in this case, it seems to be fault with the screen, so your data would be safe.
Posted on Nov 15, 2009
How do you wake up a controller that is asleep?
The majority of controllers have a sleep timer. If the chair is on for a specific time period without use, it turns itself off, or, goes into a sleep mode. The chair is in a sleep mode when the operator tries the move forward and the chair does not move and lights on the controller blink rapidly.
To solve this, simply turn off chair, wait 10-30 seconds and turn chair back on. You should be able to operate as normal.
May 31, 2014 | Pride Mobility Pride TSS300 Power Chair -...
Compaq Presario CQ50-103NR Notebook PC stuck in sleep mode
Try and perform a Hard Reset onto your laptop.
Performing Hard Reset
1. Turn off PC
2. Unplug both battery and ac adapter
3. Hold Down on the power button for 30 seconds
4. Plug everything back in and turn it on.
When you are back at your desktop screen, change the sleep mode and display settings to 1 minute to see if you can wake it back up.
If not, then load into your BIOS by pressing F10 during boot up. Once in BIOS, press the F9 key and select "load defaults". Once you load defaults, press to F10 key again to save changes and exit. After that, search the hp website using your product # on your laptop to see if there are any BIOS updated for your product.
Aug 13, 2012 | HP Compaq Presario CQ50-103NR Notebook PC
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
MY PHILLIPS LAPTOP IS MELTING!
Remove the battery and disconnect the power INMEDIATLY
This could be due to:
A) a faulty fan inside the PC (is not cooling it down)
B) a faulty battery.. there have been cases of melting and even “exploding” batteries (specially if they were not genuine batteries)
Take it to a service centre for further diagnostic.
Ed
Nov 07, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq presario f577cl wont turn on
Turn it on, then hold the power button for 4 seconds until it forces off. Turn on again.
Otherwise, turn on, remove battery, insert battery, turn on.
Please rate.
Aug 21, 2009 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
Sleep and standby
Well... Sleep and Standby are not the same. While Sleep only turns off a few things, like display, WiFi, and HDD to save energy. Standby saves your session to the Hard Disk, the reason why the laptop seems unresponsible. This is the reason to uncheck Stanby if you want a fast wake-up.
Apr 16, 2009 | Compaq Presario Notebook
Wireless not woking --Driver required
presario c700 laptop turn on wlan is not clickable...
Aug 26, 2008 | Compaq Presario 700 470024-192 Notebook
Open Questions:
hp presario cq60 connects to network but not to internet hp presario cq60 connects to networkb but not to internet. I replaced the wifi card. I've tried to connect to hot spots and to wireless routers. I can connect to them, but no internet. Says Local Only. I have tried the following... 1- Click Start, then type ncpa.cpl and press Enter 2- The "Network Connections" window will show up 3- Right click Wireless Network Connection and select Properties 4- Click the Networking tab. Click Internet Protocol Version 4 TCP/Ipv4 and then click Properties 5- Select "Obtain an IP address automatically" 6- Make sure also that "Obtain DNS server address automatically" is selected 7- Click OK Then please follow the steps below also: 1- Open Internet Explorer (even if you use another browser) 2- On Internet Explorer click Tools, then click "Internet Options" 3- Click Connections 4- Click "Lan Settings" 5- Make sure "Automatically detect settings" is SELECTED 6- Make sure "Use automatic configuration script" is UNCHECKED 7- Make sure "Use a proxy server......" is UNCHECKED 8- Click OK 9- Click Apply then Click OK I've also tried...1- Click Start, then Control Panel 2- Now click "Network and Internet" 3- Then click "Network and Sharing Center" 4- And then click "Manage network connections" on the left 5- Right click "Wireless Network Connection" and select Properties 6- Click the Networking tab. Click Internet Protocol Version 4 TCP/Ipv4 and then click Properties 7- Select "Use the following DNS server addresses:" and enter the following 8.8.8.8 8.8.4.4 (remove the old ones if you have it) 8- Click OK and wait 60 seconds or so. I've also tried... Please click on Start->All Programs->Accessories, then right-click on Command Prompt and click on Run as administrator. Then type: netsh winsock reset , and press Enter. ipconfig /release , and press Enter. ipconfig /flushdns , and press Enter. netsh int ip reset netshlog.txt , and press Enter. Then restart the computer and check. Nothing has worked. Still allows me to connect to a wireless modem or a hot spot but not to the internet. It displays "Access: Local Only". I've tried other laptops and they allow internet access using the same wireless modem or hot spot. Yet, as I stated before, When I was in the hospital, I could connect to their wi-fi and get internet access. I also can connect this laptop to an ethernet cable and connect to the internet.
Nov 16, 2011 | HP Compaq Presario CQ60-249US Notebook
See all HP Compaq Presario CQ60-249US Notebook Questions
HP Compaq Presario CQ60-249US Notebook Logo
210 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
