Question about Dell Inspiron 2200 Notebook
1 letter of my Dell laptop key (e) works inconsistently. Takes 2-3 presses to show an e on screen. No other problems.
  • carolyn_ryan Nov 17, 2009
    Thank you so very much! I appreciate your answer and follow-up assistance!
  • IQUIT May 11, 2010
    Replace the keyboard, about $20 on Ebay:http://support.dell.com/support/edocs/sy...
    Problem Solver:
  • 12 Answers
New keyboard. easy 20 dollars to spend
Posted on Nov 16, 2009
Dell latitude E/6400 blank screen worked yesterday
run the dell diagnostic by turning the laptop on and tapping F12 key when you see the Dell logo
keep pressing F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
during the test it will beep and display colored bars then ask your if the colored bars were displayed. to press Y for yes and N for no
this test the graphics/video chip on the computer to see if the hardware is working.
You can also connect it to an external monitor like a monitor that comes with a pc.Then press and hold the "FN" key and press the F8 (CRT/LCD) key to toggle the external monitor. if the image is displayed in the monitor then it can be a lcd screen or lcd inverter in laptop.
hope that helps
Feb 27, 2014 | Dell Latitude D630 Intel Core 2 Duo T7250...
Spot screen
Hello
First find an external monitor to test if its the screen on your laptop or the graphics chip in your laptop. If you have an external monitor then hook it up to your laptop and toggle the video over to see if you still see the spot.If it only shows on the laptop screen the Replace the screen.
Another thing you can do is run the built in Diagnostics
Diagnostics before windows using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen.
Dec 18, 2013 | Dell Vostro Computers & Internet
HOW TO DEACTIVATE TEH Fn KEY IN DELL LAPTOP
Hi names Rui, to turn Fn in you dell you need to:
1. Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key.
2. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens.
3. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it. So i hope this will help you.
Jul 20, 2011 | Dell Vostro 1510 Laptop
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
My Letter aon my Dell Lap top is not working, everything else is perfect I have to use the on screen keyboard for the letter a
1.u can remove every keys in a laptop keyboard.see any website first to remove the key buttons.
2.then remove the keys which are not funcitioned properly,then clear any dust
3.Replace the key bottons
Thank U sir ... All The Best...
Apr 22, 2010 | Dell Inspiron 1720 17" Widescreen...
As soon as I power on My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for...
''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for shutdown, nothing happening with that operation either.
Jan 19, 2010 | Dell Latitude D610 Notebook
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Searching for signal
The problem is with the computer, not the projector.
There are special function keys, generally with blue lettering along the top row of your keyboard. Find the one that looks like a double screen or says "CRT". Also locate the blue function key [FN], probably on the lower left on the keyboard.
Press, and hold, the [FN] key and press the [CRT] key to change to dual screen.... and wait for several seconds for the projector to detect it. If it still doesn't work after you have waited, press the key sequence again (there are 3 different screen settings).
1. Computer Screen only (normal)
2. Projector Screen only
3. Both Computer AND Projector screens
Sep 24, 2009 | Dell 2100MP Multimedia Projector
Screen only displaying keys that are on blue on keyboard
sir if u wants to type the special characters then press the shift key before pressing that button.
Apr 23, 2009 | Dell 0Y3740 Keyboard
System won't log on
try safe mode. If it works, use system restore to go back to a previous working configuration. If safe mode does not work, try the last known-good configuration. Restart the computer, then as soon as the Dell logo shows up on the screen, press the F8 key repeatedly until you enter the Advanced Options Menu. Use the arrow keys to select Last Known-Good Configuration, then press Enter.
Jan 11, 2009 | Dell Inspiron 1150 Notebook
Dell Inspiron 2200 Notebook Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
