Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Have had my bissell for 5 years. has worked great. Just went to use it today and I have no power to it. It's not the breaker.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrgts
Posted on Sep 30, 2010
My Bissell Spotbot Pet cleaner stopped working. Took it out of the closet, plugged it in, No power? It worked great the last time it was used.
Well, if cycling it manually doesn't work and replacing the controller board didn't make a difference did you check the flex hose sensor? Bots won't run unless everything is clicked into place.
"Testimonials" don't continue the thread :)
I managed to dig up a copy of the service guide since I haven't owned a spotbot in years. http://evacuumstore.com/images/spotbot-repair-guide.pdf
Mar 22, 2017 | Bissell SpotBot Pet Spot Cleaner
My bissell 6583 worked fine for 2 years no problems . Today I vacuumed my sons room, turned the vacuume off, 2 hours later it won't turn on... Help please I'm in the middle of my spring cleaning.
Hi Mary. I can understand how frustrating this can be especially when Spring cleaning.
Here is a quick link to troubleshooting steps to assist you with the no power: http://www.bissell.com/FAQDetail.aspx?id=1457&cid=ccsocial
Apr 14, 2013 | Vacuums
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
No power to my oreck vacuum
You can always check the brush area with the vacuum unplugged. If there is an obstruction remove it. If you are unable to get it working you can check out some of our great models like the PowerClean, Healthy Home and Lift-Off Multi Cyclonic vacuums that have 12 amp motors an excellent suction. Specials are show at our website http://www.bissell.com/upright-vacuums/
Our PowerClean and Healthy Home vacuums have a 5 year limited warranty and the Lift-Off Multi Cyclonic has a 3 year limited warranty.
Apr 20, 2012 | Vacuums
My vacuum worked just fine... i went in another room to use it and now it won't turn on no matter what outlet i use!
If it works in the other room's outlets, I would think that it might be tripping the circuit breaker for the room it isn't working in. Check your circuit breakers.
Dec 07, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
No manual for my Bissell Rug Shampooer
Follow this link. It is on bissells website and it is in PDF format so you can print it for free.
http://www.bissell.com/images/UserGuides/1696.pdf
Jun 29, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 1699 ProHeat Cleaner
If it is completely dead, then either a bad cord, switch, motor, or a broken connection, it will have to be taken apart to find the problem.
Aug 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell bagless vacuum-less than one year old
http://geeksquad.fixya.com/ThreadView.aspx?prdid=50020&thid=706758
posted by nat9 on Jun 25, 2008
I was vacuum and the machine worked for 5-7 minutes than went with a sickening sound and quit on me....dead, dead...I CANNOT FIND MY MANUAL.PLEASE HELP
PS-perhaps this one has a private circuit breaker internally? THANK YOU,NAT
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 3590 Cleanview Bagless Upright Vacuum. The vacuum is less than a one year factory warranty and the best thing to do is to contact the Bissell Factory to see where the nearest factory authorized dealer is in your area including there address and phone # and they should be able to fix or repair the vacuum under the factory warranty. Also, you can order an owner’s manual from the factory and to give them the model # and serial # and they will send one out in the mail or they will instruct you to download the owner’s manual from the Bissell website. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 25, 2008 | Bissell 3590 CleanView Bagless Upright...
No suction
I had exactly the same problem with my five-year old my Bissell 7920, and it's probably a broken pump belt.  See page 19 of your instruction manual for how to replace.  The Bissel ProHeat belt accessory pack costs $3.99 and you get a pump belt and a brush belt.  Since you have to first remove the brush belt to get to the pump belt, you might as well replace both. The first time I did this it took me 15 minutes, but now that I know the drill, doing a belt replacement would take about 3 minutes.
Apr 10, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
37 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
