Question about Frigidaire ATF6000ES Front Load Washer
After sitting during the week water is filling back into the machine
  • 6,784 Answers
HI. This will occur if the water inlet valve is malfunctioning(Not closing all the way). Follow The procedure below to confirm the damage.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the washer is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Posted on Nov 15, 2009
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
My Giotto Premium drops water from time to time - it runs out the holes in bottom of machine and makes quite a mass of water either side of machine on bench - we can't see a pattern - but do leave the...
Did you find a solution yet?
If your machine isn't plumbed in, so you have to fill the reservoir, I find it is easy to overfill, and the water runs out over the lip. I placed a fishing float with the long bit sticking up through the hole, so I can see when the water level is too low.
Dec 27, 2010 | ECM Giotto Espresso Machine
Refilling system
Run a clean cycle, might sort it out,
Sounds like it is scaled
Dec 14, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Atlantis washer
Dear Spencer,
OH the trouble I have seen with my washer. Its only 8 years old and I had the same problem with mine it would fill up the rinse cycle and then just sit there with the water in it. I had a tech come out and he told me I wasn't distributing the clothes correctly, mind you I'm 54 and I think I know how to do laundry!
However I had just 1 month ago replaced the water pump because my son decided he wanted to do a weeks wash in one load. So what I think happened is that somehow the machine was knocked out of being level. The guy said he lubricated the motor cradle and leveled the machine, knock on wood just for today the cycle is running all the way through. Hope this helps
utah55
Jun 24, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Frigidaire ATF6000ES Front Load Washer Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
