Cell Phones Logo
Posted on Nov 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound i know my tracphone is on and i am trying to call out and i think it is going thru but i cant hear anyting even when i dial other than that the phone is okay i can see everything and what it is doing just no sound i tried puting the volume up doesnt seem to help
Anonymous
Level 2:
New Friend:
  • Expert 137 Answers
  • Posted on Nov 15, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
137
Questions
Helped
30880
Points
359
Make sure your headset is not set to mute if that doesn't seem to be the problem your speaker may be damaged or a wire might be loose
1helpful
When adding minutes the phone says system unavailable
I know this is old, but it still is an issue. In my instance, my trouble was that I have a TracPhone, but the Service Provider is Net 10. I thought you could buy a TracPhone OR Net 10 card, but you can't. Even tho you have a TracPhone, you must purchase the particular service providers card or the code won't go through. Bad part is it won't tell you the code is bad; it just says that Service Unavailable. Try Later. Same if you go online.. it doesn't do anything. What I did was call someone on my contact list; it went to the automated system, and I went through the prompts to where it asked for my pin number. It says PIn is not found in thier system. I tried it two more times and then it hooked me up to a live person. (you can just hit 0 to go straight there) The person after I explained it told me I had bought the TracPhone Card and had to get Net 10 card. (My service Provider; yours might very well be different) They told me they would transfer the TracPhone number to an equivalent Net 10 card. Then they transfered me to another person and it was done after about 20 minutes. Phone now has the minutes I thought I had lost. <:o)
I cant hear anyting on My toshiba when im watchin tv but if i put my bluray i can hear it bt not when im watchin tv
Please make sure your audio cables are connected properly from your cable box or DVR to your TV. Let me know if you need more help.
2helpful
Ok, if i record mself singing and upload it to the computer...will i be able to here me sing there or not at all???
Welcome to Fixya. All digitals camera has a features of video recordings, however they have the difference when you try to review or watch it thru the camera itself. I have the same camera as yours, First I thought that my camera was damaged because I don't hear any sounds at all when I'm trying to view/watch my brother's gradustion day. When I try to transfer all the data on my computer, thinking that trying to re-format the camera will be the resolution for my issue to hear the sounds of my recordings. While listening to a music while reviewing my pictures on the computer, I heard a different sounds, then when I try to pause my music, I'm happy to hear that its my brother's video on his graduation.
The answer to your question if your going to upload your video on your computer, YES! you can hear the sounds of your recordings thru your computer.
Please let me know if you have any question.
Thank you for using Fixya,
seancarlisle
The door for the soap dispenser is stuck half open even after I ran it thru a couple of cycles
This may or may not be the answer you are looking for but I know with mine the soap dispenser will not close unless the outside dial is completely in the "off" position. Trying turning the dial clockwise very slightly. If you hear a click and it resets the soap dispenser position that should work. Otherwise I have no idea. :)
2answers
Audio big prob
Have you even installed the sound drive yet?
Psp
u fryed your memory card buy a new one
Earpiece
I Think There maybe a problem with the internal speakers.does anyother sound work or is it just the dialing tone and voices?
if its just dialing & voices check in the call menu that sound IS NOT muted.This may solve the problem.
if no sound works at all,maybe its is damaged but you havent noticed? Take it back to the shop you bought it from and tell them about the problem,afterall a phone that you cant ring people on is usless! Or ring your network provider to see if it may be repairable under warrenty.
Hope That Helps.
Good Luck
Regards.
Sophie x
No sounds
your connection is effed. call your provider, it's definitely their problem. and as for the dialing, you probably just have it on a setting where you can't hear the buttons pressing as you're pressing them. i think that is in settings.
Sound going in & out
What is happening is that she is accidently pressing the "up" portion of the rocker switch on the left side of the phone when she flips the phone open. You will notice (try this on purpose)that when you open the phone while holding the rocker switch up, that there are no key sounds when dialing a number. Oh yes, the number will dial and even show connected on the screen--but no sound!!!. Now, to hear the dialed number ringing, you must press the speakerphone button below the rocker switch. You don't have to turn on the speaker phone, just pressing this button restores sound. On the next call however, the sound will STILL not work until you press the 4 way toggle button in the center of the phone. Now the phone is restored to normal status. It took me about five hours and a million combinations of buttons to figure this out. See my post, from 121212. thanks [email protected]
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
