Question about Motorola Mobility RAZR V3
I forgot my lock code how do I fix this? I can't get into my msgs or make calls?
Forgot Lock code of LG RD 3500
Go to the costumer care and ask them for code ... they'll ask Ur authentication and willprovide you the pin.
Sep 22, 2009 | LG RD2030
Phone memory was lock , need security code which i forgot
call your service provider from another phone, then tell them your problem. they should be able to fix it remotely.
Jun 13, 2009 | Nokia 6085 Cellular Phone
I setted security code on my nokia 5310 and now i forgot it now i cannot change my security code imei-number is 356419025200108
try to reformat your phone key this in *7370# then press call button but keep in mind when you reformat your phone everything will be remove such as the contacts,msgs,calendar,mp3,pictures,videos..etc
Apr 01, 2009 | Nokia 5310 Cellular Phone
Got new lg 8600, forgot my securtiy code.
Call your phone company they have a master reset code for this kind of situation.
Mar 17, 2009 | LG KG800 Cellular Phone
Forgot the N70 lock code
remove your sim card and memory card, then, press #3 button,* button,call button and power on switch at the same time for about 10 seconds, then wait untill it reboot... then its done no more unlock codes.
note: this process may erase all your data such as photos,videos,contacts,msgs etc.
but this tip can remove unlock codes
sexy-ym
Sep 05, 2008 | Nokia N70 Cellular Phone
Forgot my security code
your phone has to be full factory set... doing this, it will remove the security code as well as the data saved in your phone, eg; photos,contacts,msgs,
but im sure it wil help you a lot.....
remove your sim card and memory card, then, press #3 button,* button,call button and power on switch at the same time for about 10 seconds, then wait untill it reboot... then you got your phone fully restored..... security code removed..
sexy-ym
Sep 04, 2008 | Nokia N70 Cellular Phone
Forgot my lock code
Dear my keypad light is not working please tell me how can i fix this problem
Regards
Ali
Aug 17, 2008 | Nokia 6630 Cellular Phone
I forgot my security code n95
after months without my n95 and hours of scannin the internet i have found the solution to the lock code!!!! if u hav totaly 4goten the code u will need to flash the fone but...... if like me you are 100% sure the code u keep entering is correct then here is how to fix it!!! when changing your code u would have enterd a 6 digit code and re-enterd it to make sure it is correct yes? all went fine! wen entering it again it faild? thats where the problem lies. enter only the the 1st 5 digits of ur code and all should be fine!! if this fails turn off ur n95. press and hold the green key, the # key and the 3 key all at the same time as turning the fone on. keep them held untill the the lock code needs to b enterd. then repeat the 5 digits of ur code. unfortunatly u will loose contacts and msgs etc but it works! have fun!
Jun 19, 2008 | Nokia N95 Cellular Phone
Forgot SIM lock
i forget my sim lock number mobile no 3207647710
Oct 12, 2007 | Samsung SGH-D500 Cellular Phone
Motorola Mobility RAZR V3 Logo
78 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
