Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
TRouble getting the door to close without banging into the overhead motor. Is there a manual available to help?
  • Don Maggard May 11, 2010
    Make and model would help.
    President:
  • 3,197 Answers
I would remove the logic board and look for loose connections on the printed circuit.
Posted on Nov 16, 2009
Door won't close
Your not clear what is going on but my door would not close because the sensor near the bottom of the door as not lined up with the other side. they both have to be in line with each other and also if there is dirt even a leaf over the sensor on either side it won't work either. Is your sensor wire on the over head box out in the open where it should be? If its not opener problem I don't know as you are not clear.
Dec 31, 2015 | Building Materials
SP229/GT912 remote light goes on but doesn't open or close what do you think?
Not much info here. Do you hear the motor running? If so, there are some plastic gears that strip out quite often. The door won't close if your photo sensors across the door are messed up. Look at the overhead motor, get the model #, get the manual from the net. I found manuals for many of them. They have trouble guides usually.
Dec 13, 2015 | Building Materials
My rear automatic door on my 2008 gmc acadia will only work if I manually open it. when I do open it you can hear the motor for the door running but it will not open it or close it. I have to open it...
Drive chained is off, I have had to do many repairs were a automatic door would not open/close, each one is different, basically need to take apart and inspect?
Mar 04, 2015 | 2008 GMC Acadia
How do i manually close the sunroof of my 2007 e320
You have to remove the overhead control unit (front dome lamp assembly) to gain access to the sunroof motor(link below) You can then put an allen wrench/socket into the drive motor for the sunroof and turn to close. This works if the sunroof motor has failed. If the problem is the switch, you might get lucky by pointing the key at the IR pickup on the driver's door handle and holding the lock button. That should close all of the windows and the sunroof. Mercedes 211 overhead mirror removal
May 04, 2014 | 2007 Mercedes-Benz E320 BLUETEC Sedan
Garage door will not close
Make sure nothing is blocking the sensors on the floor at each side of the door.
Aug 23, 2013 | Building Materials
When the overhead open switch is pressed, the passenger side rear door opens about 2 inches and stops. After opening manually it will not close with switch. When manually closed, will draw in last inch and...
It sounds like there are 2 motors involved, one that latches and unlatches the door, and a second that moves it out of the way or brings it back.
The one is working, the other is not.
First, look for a blown fuse.
Disconnect that 2nd motor (if you can find the connector), and use a volt meter to see if power is getting to the motor and the motor does not work, or the power is not getting there.
Jun 21, 2010 | 2005 Chrysler Town & Country
Hello, I have a 2002 Dodge caravan and I am having trouble with the driver side power window.The window will not go up or down until I bang on the door panel. It acts like a broken wire shorting out. Is...
this problem is caused by a defective motor, the motor's brushes are sticking, so banging on the door jars them loose and it works again, this is a classic symptom of a defective window lift motor.
Oct 06, 2009 | 2002 Dodge Caravan
2001 dodge grand caravan power sliding doors not operating
You may have already checked this but there is a switch located close to the overhead button that will disengage the door buttons for child safety, is that turned off?
Jan 06, 2009 | 2001 Dodge Grand Caravan
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
85 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
