Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag model MDB7160AWB dishwasher fills and starts wash cycle. approx 2 min into cycle it shuts down
  • 1462 Answers
SOURCE: dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
Posted on May 04, 2007
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
  • 236 Answers
SOURCE: my carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Posted on Mar 16, 2009
honeymokey
  • 3113 Answers
SOURCE: Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Posted on Apr 08, 2009
bigg t
  • 640 Answers
SOURCE: dishwasher will not drain
What is the model?
Posted on Apr 12, 2009
My maytag washer when i start it it fills then the cycle starts the timer will count down til it get to 13 min then jumps down to 3 min then shuts off it skips the wash cycle and the rinse cycle befor
sounds like you have a problem with the main control board. you can order a new one from appliancerepair.com and if it turns out not to be the problem they allow you to return it for a full refund. great company!
May 26, 2014 | LG Washing Machines
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
Maytag mdb7160awb with light rise and clean flashing lights.
Sounds like the tension mechanism that advances the cycles is broken. Many of these things are made of hard plastic (brittle) and will break over time. Any metal parts inside it are also prone to rust. If the dishwasher is older than 5 years consider getting a new one. Otherwise, try an locate a parts seller for your make and model on-line. Many offer schematics (parts diagrams) that will help you locate the part(s) you may need. You will probably need a TORX driver set to disassemble the the front to get to the cycle advance mechanism. I would remove it from under the counter and take it somewhere you can get into easily and see what looks broken first off. With the parts diagram printed out, go over the whole mechanism. Good Luck
Sep 24, 2012 | Dishwashers
Wet dishwashing soap
make sure that the you let the hot water run for 2-3 min to make sure it is hot going into machine or it will not break down the soap.if the dispenser is opening then it is a tempproblem. let me know if my assistance was any help with a 4 thumbs up post
Feb 27, 2010 | Maytag 24 in. MDB9750AW Dishwasher
My dishwasher has water going in to it and it drains but it's not making it to the arms, my dishes are still bone dry after all cycles even pre rinse.
it appears ur wash motor is not running.try this-start the unit and let it run for 2 min( this is the water fill period) and after 2 mins u should hear motor running and water splashing sound.u can even open the door and look for water falling from the spray arms.but after 2 mins if u hear only a humming sound and no water splash sound then motor is bad and needs to be chgd.drain motor is seperate for draining the water.
Aug 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Tank temp
check to see if your element is scaled up or your element may be damaged
Nov 21, 2008 | Hobart AM15T Dishwasher
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher shuts off during cycles
thats what it soundslike to me here aoart number which is the entire assy w/both switches included 99002254 retails for about $25
Nov 05, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
70 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
