Question about Bosch Dryers
Bosch Axxis WTA 3510 Electric Dryer heats, but not very hot and drying a load of clothes takes 90 min. to 2 hours. Our dryer never seems to get very hot. It does heat up, but only barely warm and takes forever to dry clothes. Does anyone know what is the optimum operating temperature inside the the dryer when it is drying clothes? Is there a way to adjust the thermostat on it to make it heat up more? Mark Mongold
textonor
  • 130 Answers
SOURCE: Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Posted on Jan 06, 2008
maklean
  • 1665 Answers
SOURCE: Service Manual
http://www.servicetechhelp.com/index.php/downloads/6124
Posted on Jun 26, 2008
  • 1531 Answers
SOURCE: Bosch Axxis WTA 3510 Electric Dryer. I changed the
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Posted on Sep 16, 2009
rylee_smith
  • 8619 Answers
SOURCE: I looked at the cylindrical fuses in the back and
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that's fine then the Heating Element should be checked. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 18, 2010
  • 351 Answers
SOURCE: Bosch AXXIS dryer # WTA 3510 uc slipping /
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Posted on Sep 30, 2010
Testimonial: "Will try it with help of a friend. Sounds much less expensive than replacing motor as Bosch dealer suggested. Thanks"
Clothes are not drying
heating elament went out need to replace it
Aug 12, 2013 | Bosch Axxis WTA 3510 Electric Dryer
Dryer runs, rotates, and air blows but does not blow hot air, therefore cloths will not dry.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 13, 2011 | Bosch Axxis WTA 3510 Electric Dryer
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
My Bosch Axxis electric dryer Mod. # WTA3510UC 82/IV takes a few cycles to dry if it dries completely. The laundry doesn't seem to get warm no matter the setting. Have checked exhaust, cleared lint from...
i would check the actual electrical connections, to both the unit, and the downline connections to that actual element itself, its unusual for an elemnt to only go a lilttle bit... it works or it doesn't...
since you seemed to be very knowlegable, ohm
out the element as well as your plug and outlet
ther emay be a loose connection somewhere
Oct 13, 2009 | Bosch Axxis WTA 3510 Electric Dryer
How far should the dryer vent be from the wall to the dryer?
No, you do not want the dryer vent crushed at all. Go to Home Depot and find a 4 inch adjustable 90 or something along that line. The problem will be that your clothes will dry for alittle while and then you will stat noticing longer and longer dry times
Feb 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch WTA4108 Dryer Not Heating
check and make sure you have 220 volts leving panel and @ the dryer motor runs on 110 volts takes 220 to heat
Oct 19, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch axxis 3510 dryer doesn't dry clothes
well first check the Thermal area inside the unit, if you have an idea doing this, it could possibly easily for you to do the work.. on the thermal area check for any burn fuse or any faulty parts relating or was connected on the thermal area.
Jun 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
60 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
