Question about EMTEC Magnetics Group Computers & Internet
I have had this flash drive since last December. Worked perfectly until this morning. Suddenly, Windows Vista lists it as a Removable Drive instead of an USB Drive as usual. I cannot access this drive. The file presently on it have yet to be backed up; therefore, I am in dire straights. What can I do to access this drive?
  • 2 more comments
  • bks2009tas Nov 15, 2009
    The solution you suggested did not work. There is no Summary Tab. I entered a name under the General tab which was deemed invalid. Other available tabs are Tools, Hardware, Sharing, and Customize.
    This did not work. There is no summary tab. When I right-click and select properties, there is a General tab, followed by Tools, Hardware, Sharing, and Customize. There is no name/label. The type is Removable Disk with an Unknown File System and No indication of Used or Free Space.
    When I type a name in the label. Windows says that it is invalid.
    Comments:
    Nov 15, 2009 - The solution you suggested did not work. There is no Summary Tab. I entered a name under the General tab which was deemed invalid. Other available tabs are Tools, Hardware, Sharing, and Customize.
    Nov 15, 2009 - This did not work. There is no summary tab. When I right-click and select properties, there is a General tab, followed by Tools, Hardware, Sharing, and Customize. There is no name/label. The type is Removable Disk with an Unknown File System and No indication of Used or Free Space.
    I will try this; but, no files were deleted. The flash drive is inaccessible via Windows
    Guru:
  • 830 Answers
Hello and thank you for using Fixya's services.
You may be able to download a free software to help you retrieve your files. Please visit this link and check out the software they offer. It looks promising.
http://www.aplusperfect.com/articles/recover-deleted-files-from-a-flash-drive-for-free
Please let me know if you have any questions.
Posted on Nov 15, 2009
  • Jennifer DeLaCruz
    Jennifer DeLaCruz Nov 15, 2009
    This will also "pull" your files from the thumb drive as well.
  • Jennifer DeLaCruz
    Jennifer DeLaCruz Nov 18, 2009
    I wanted to check and make sure that I assisted with the problem you were having. Please let me know if you have additional questions.
    Thank you for using Fixya!
    Jennifer
    Brigadier General:
  • 3,513 Answers
There is a simple fix for this.When it shows "Removable Disk" try to right click and hit Properties. Then fill in a Name in the Summary tab (your name). Suddenly you should get a pop up.It will start working again.
Thanks for contacting Fixya.com
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
I have a laptop with preinstalled Windows Vista Home Premium which has worked well until today. I used it this morning but this afternoon I am unable to 'logon' after switching on the computer&...
I would like to introduce Windows Password Key 8.0 . it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It creates a password recovery CD/DVD,USB Flash Drive for home, business and enterprise. It works perfectly to reset your Windows password. You can download it from http://www.lostwindowspassword.com
May 21, 2010 | Microsoft Windows Vista Home Premium with...
Constant blue flashing light,computer will not detect
I dropped my Trekstor 500GB hard drive and now it registers as a removable disk with message "please insert disk into removable disk". My computer is a Windows vista. Can the Trekstor be repaired and can I retrieve my data. Until now it worked perfectly. Paul
Feb 12, 2010 | Computers & Internet
My usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Dec 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
'Please insert a disk in to the removable disk drive k"
Same thing happens to me .My 8gb silicon usb flash drive got the same error, please insert a disk into drive, the name of my drive weas changed into Removable Disk instead of the name(Sanctuary which is what i used) It said ni media ,and it was registered as XXXXXXXX U167CONTROL USB DEVICE can anyone help me with this.
Nov 25, 2009 | Electronics - Others
My internal hard drive is recognised as removable???
Your problem is Vista. It is the pits and by far the worst modern OS, second only to Windows Me. (Millenium Edition).
You need to start at the beginning. Go into DOS, use FDISK to Format the Drive, Go to BIOS and Assign it as the main disk. Disconnect any other HDs if you have them. Reinstall Windows 7 Pro if you can find a copy.
However, did you try this?
http://www.tomshardware.com/answers/id-1983753/hdd-showing-removable-disk-drive.html
hard drive suddenly became recognised as removable disk Google Search
Mar 20, 2017 | Fantom Titanium II (TFD500C16) 500 GB USB...
How do I get started using a USB flash drive and how do I set up a security system?
hey, heres something that would help u:  Copying files to a flash drive on a PC:
  1. Open My Computer and see which drives are shown. Most computers, for example, have a hard disk such as a C: drive and a few removable storage devices such as a floppy drive, a CD-ROM drive, and perhaps a zip drive.
  2. Insert the flash drive into the USB port and watch to see where the USB flash drive appears. Most will appear as removable storage, but some will instead appear as hard drives. Note the name Windows is using to refer to the flash drive ("Removable Disk (G:)," for example).
  3. Open My Documents or the location from which you want to transfer files to the flash drive. Select the files or folders you want to save to the flash drive by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files you wish to save.
  4. Right-click on the file(s) or folder(s) you selected, then select Send to, then select the name you saw appearing in My Computer for the flash drive ("Removable Disk (G:)," for example).
  5. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  6. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
Copying files from a flash drive on a PC:
  3. Double-click on the flash drive to locate the file(s) or folder(s) you want to copy to this computer. Select the files or folders you want to copy by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files or folders you wish to copy.
  4. Right-click on the files or folders you have selected and choose Copy.
  5. Open My Documents or the location to which you want to transfer files from the flash drive.
  6. Click on the Edit menu, then select Paste.
  7. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  8. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
    ok_msg.gif                                      =========================================================
For the security system setup go through the following link .. http://www.rohos.com/configuring_usb_stick_logon.htm
if u require some other sort of security system let me know.
cheers
Oct 13, 2008 | Computers & Internet
Samsung ml-1740 printer - their driver not compatible with my Windows Vista
you must go to printer in control panel, then right click the desired printer icon, then click properties, then click on Port. then if using usb port, you must check each port untill you find the correct usb port that you are connected to (click apply each time). may take a couple tries untill you find the correct usb Port that the cable is connected to. worked on my HP desktop, finally
Sep 01, 2008 | Office Equipment & Supplies
HL-DT-ST DVDRAM GH20NS10 - DRIVE FOR WINDOWS VISTA
heres the solution.worked like a charm
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
May 20, 2008 | Computers & Internet
USB flash disk not working
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Jan 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
46 people viewed this question
Top EMTEC Magnetics Group Computers & Internet Experts
JonSnell Electronic
JonSnell Electronic
purushottam aher
Level 1 Expert
Masood Rasool
Level 1 Expert
Are you an EMTEC Magnetics Group Computer and Internet Expert? Answer questions, earn points and help others
