Question about Bose & Wave& Music System
What is BOSE WAVE CD II's laser head model number? My laser head's soft circuit line damaged, when clean it. Thanks!!!
  • bg1dy Jan 09, 2008
    sss
    Genius:
  • 1,689 Answers
You must contact Bose directly for replacement parts. Most manufacures normaly sell the complete transport as a replacement part.
When changing the laser, or simply removing and re-installing the original, the proper calibration set-up will be required. This cannot be done by eye or ear. This also includes installing a complet new laser assembly.
Jerry G.
Posted on Apr 29, 2008
Bose sound
You could try to clean the laser, with a special cleaning disk. Don't try to clean a laser by opening the player, you will damage the system.
If it is a CD burned in a PC, it also can be the laser is now a bit less, not capable reading CD-R or CD-RW, and still can read normal CD's
Read my other post over CD players
Jul 26, 2014 | Bose & Wave& Music System
Bose wave awrc-1g cd player spins but does not play.
You have done what i would have suggested, the Bose Wave unit will need to back to Bose for service, and there is a good chance they will need to replace the laser pickup assembly and cost should be considered even thoe it is top of the line.
Apr 02, 2012 | Bose Wave radio/CD remote control -...
Bose Wave... disc one will play...others give Disc Error message? Hellp
hi,
your cd players laser eye unit have some problem. its need cleaning. just open the cover. make sure that the power is disconnected. take an ear bud. clean the Lance on the pick up. u can find it inside the cd mechanism.do not use pressure cleane jauntly. do not use any harmful chemicals . it will damages the Lance. use only ear bud. after cleaning close cover .connect the power and check it. if fault remains, replace the eye unit with the same number specified in its label.
ok
Dec 15, 2010 | Bose Audio Players & Recorders
Bose Wave Radio/CD clock running very slow. Now that I've moved it across the pacific ocean(US to NZ) the clock is suddenly running very slow, losing 10-15 minutes per hour while running on any...
My guess is that the clock in the radio is based off of the AC line frequency (not voltage). In the US the line frequency is 60hz (hertz). I'm guessing that the line frequency in NZ is 50hz, which would seem to explain that extreme amount of time loss. I would check with Bose, but I'm betting they make different 50hz models for export.
May 16, 2010 | Bose Wave Radio
The cd player is not reading the discs. The read out flashes and blinks but it does not read the music off the disc.
Try removing the cover and clean glass laser eye lens with rubbing alcohol and cotton swab. If cleaning doesn't work, then laser lens circuit will need to be tested and replaced. You can use an ohmmeter to test the capacitors and circuit.
Nov 13, 2009 | Bose Wave Radio
CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Jun 28, 2009 | Bose Wave radio/CD remote control -...
Bose Wave/CD Radio- CD Skipping
Below are some basic instructions of how to clean the laser:
http://www.wikihow.com/Clean-a-CD-Player
If the fault is more involved the unit will have to be serviced, you should contact the manufacture to find out about who in your area can service your player.
Jerry G.
Mar 22, 2008 | Bose & Wave& Music System
Bose wave radio/cd often cd spins but does not play, sometines will correct if I turn unit off and on. HELP tHANKS
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Nov 27, 2007 | Bose & Wave& Music System
Bose & Wave& Music System Logo
890 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
