Question about Proform Crosswalk 500 Treadmill
I am trying to repair the slippage on my Proform Crosswalk Caliber II belt. How do you adjust the belt and please provide detailed directions. Thanks so much Pau;
    New Friend:
  • 64 Answers
Most treads have two bolts on the rear roller. To tighten turns these bolts clockwise. Depending on how bad the problem is, I usually turn a 1/4 turn at a time. Walk on the machine to check tension. Once tension is correct turn right side bolt or left side bolt to center belt. Remember belt will travel to side with least resistance. ie.. if you want the belt to go to the left- tighten the right side(clockwise) Centering the belt is easier with machine running at about 2-2.5 if belt is not rubbing on the sides.
Posted on Nov 18, 2009
No replacement console for PFTL71505.0 Proform Crosswalk Caliber Elite
go to www. fitnessreairparts.com or www.doctortreadmill.com or www.treadmillpartszone.com
God bless you
Jun 19, 2012 | Proform Crosswalk 500 Treadmill
Proform Crosswalk display will not work. Belt and incline work fine. Have changed batteries, adjusted reed switch to within 1/8
adjust the REED switch, see the diagram for to do it. clean, and tight the connector very well.
God bless you
May 11, 2012 | Proform Crosswalk Ls Treadmill Walking...
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
I have a proform crosswalk caliber elite treadmill model # PFTL71505.0 and only buttons #3 and #9 work and no others. Should I try the same fix that I see on other posts where they slice the ribbon cable...
1) TRY TO CLEAN THE CONTACT, by corroded or dust, or loose connection(tight).
2) try to open the control panel and clean with contact cleaner.
3)adjust the Reed swithc +Optical sensor
4) Do not connect other pins, you can provoke some short circuit or bad functions, and provoke another errors or jamming some I.C.
Sep 08, 2011 | Proform Crosswalk 500 Treadmill
When i try to run, it stops and then goes. Its like its trying to hard to go, you cant even run. its a proform crosswalk caliber.
hi it seems like the belt on the motor has either slipprd or needs to be tightened, i had the same problem. i just tightened the belt on the motor and its working fine!
Nov 20, 2010 | Proform Crosswalk 500 Treadmill
How do I adjust the belt on my Proform Crosswalk Gtx? The belt is too far to the left on the rollers. Thank you.
You can adjust the rear roller bolts tighten the left side to make the belt come back to the right. If it will not come back you may have a broken endcap causing the problem
Aug 09, 2010 | Treadmill Doctor Proform Crosswalk Gtx...
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
Proform Crosswalk Advanced 525X the belt slips and it squeaks when slipping.....I have tried adjusting the end of the belt but that doesnt seem to help
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
Nov 30, 2009 | Proform Crosswalk 500 Treadmill
Proform Crosswalk 500 Treadmill Logo
347 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
