Question about Cables Unlimited InterAct Racing Wheel V3 (ACC-SV280) Wheel And Pedals Set
The wires for the pedeals are not wired in
The wires for the pedeals are all broken off I still have the wire from wheel to pedal but thats all no wires are in the pedal housing can you tell me how to rewire it
  • William Mishler Sep 12, 2012
    Shows what you know I figured it out on my own.
    Problem Solver:
  • 6 Answers
You can get it repaired , trying it yourself wont work well.
Posted on Nov 18, 2009
2005 dodge 2500 diesel it has a new brake controller. trailer brakes work when you push the controller manualy but trailer brakes don't work when you push the brake pedal
there is likely a wire that goes from your brake pedal switch to the trailer brake controller this wire is probably broken or not hooked up. if it is hooked up and no wires are broken I would start making sure everything is hooked up right.
May 28, 2015 | Dodge Ram 2500 Cars & Trucks
How to fix floor pedal on riccar 8850
Your 8850 is probably over 15 years old, almost all parts are interchangeable with the 8955 or 8925 model made today. You may need to replace the pedal if the catch has worn or broken. There is no wire on the. Pedal assembly but there is a spring that goes on the pedal shaft to make the pedal spring back after you push on it.
Oct 11, 2014 | Riccar Vacuums
How do i fix a fisher price power wheels jeep
If you have a volt meter, switch the volt meter to 12v, locate the motor in the back wheels and if you can see where the wires connect to the motor touch the terminals of the volt meter to the two connections and turn on the power wheels press the power pedal and see if you get a reading of 12v. If you can't touch the wire or where the wire connects try disconnecting the wires and testing it that way. If you have 12v at the motor then it seems the motor is shot. There should be two motors one fit each wheel and its unlikely that they would both go. If you don't have power at the motor try following the wires to the pedal and also the forward reverse switch. Test these in a similar fashion. Hope that helps
Nov 20, 2013 | Baby Gear
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
Brake lights not working
First check fuse. If good go right to brakelight switch on top of brake pedal under dash. Check for power into switch pedal up. If you have power in, press pedal down you should now have power out. If not you need brakelight switch. If you do have power out you have corroded or broken wire from switch towards taillights. Usually back by rear wheels. Need to trace wire to where there is a problem.
Jun 14, 2010 | 1999 Chevrolet Tahoe
Shifter stuck in park,when engin is running. Able to move shifter if igniion swith is turned, but not to started
The problem sounds like it is the shifter interlock solenoid located on the steering column is not releasing the shifter lever. The shifter interlock is supposed to release the shifter lever when the ignition is in the run position and the brake pedal is pressed down, and I have found that about 90% of the time the problem is either a bad switch on the brake pedal lever, or it will be the wires that connect to the switch on the brake pedal lever, and I have found many times that the wire is actually broken right up inside of the wire connector and hanging on by the insulation making it appear to still be connected. Most vehicles use only one multi-function switch on the brake pedal lever to control functions like the brake lights and the cruise control, but Ford products are good at using two switches on the brake pedal lever. Be sure to check all of the wires to the switch(s) on the brake pedal lever very well for broken wires especially at the connectors to the switches. If you can use a power probe or a volt meter to check that power is flowing through the switch(s) properly, and you do find that the switches have power to them and through them when the brake pedal is pushed down, then the shifter interlock solenoid will either have a broken wire at it, or the shifter interlock solenoid is malfunctioning and will need to be replaced.
May 22, 2010 | 1994 Lincoln Town Car
Theres no tension behind the gas petal when i press it
The pedal is connected to a wire cable which runs to a valve or flap of some type at the intake end of the fuel injector under the hood. Either the cable has broken, or the spring which keeps the fuel injector opening closed down to idle position has broken or the cable has come off at one end or the other. Raise the hood and have a companion move the pedal up and down while you find the accelerator cable housing, most likely will be black. If the stiff wire cable inside the housing is moving with your friend's movement of the pedal then you should look to the end of the cable. You will see a small grooved wheel and the cable lies in that groove, and its movement turns the wheel which moves the flap inside. If the cable is not moving then your accelerator cable has broken or come loose at the pedal end.
Apr 28, 2010 | 2002 Toyota Camry Solara
Hummin sound when turning to the left no trac light comes on and the brake pedal pushes back
You have a partially broken wiring harness to one of the front wheel speed sensors. As the wheels turn back and forth they tend to fatigue the harness and cause an intermittent brake in the wire , this makes the computer think that you have lost traction and triggers the ABS/Traction control system. You'll need to have the computer scanned for abs codes and figure out which sensor is showing as bad. If the problem is not bad enough yet, the code may not have stored. Either way, you will have to get an ohmmeter and carefully test the resistance of the speed sensor harnesses to find out where it is broken. An alternative is to just replace the wiring between the sensor and where it fastens to the frame. Any place that the wire has to move when the wheels are being steered is suspect.
Mar 16, 2010 | 2002 Buick Century
Will not steer...all other buttons work
Probably a bad potentiometer on the wheel. This is the device which defines the rotational position of the wheel shaft. It may also be a broken wire to that device.
Oct 15, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Pedals broken on xbox 360 MS wireless wheel
I've see a lot of posts where people have had issues with the Microsoft racing pedals not working properly. Usually the throttle just races away when it is suppose to be at idle. I had this problem and after taking apart the pedal set more than once to try and fix it - it's made so cheaply - I gave up.
So, if you want a good fix, here is what I did. I got a set of Madcats 2 pedals, which are X-box compatible (craigslist) - other pedal sets may work but then you would have to figure out the wiring on your own which took me considerable time NOTE: These do not have to be the Madcats pedal set from the force feedback type, just the standard pedal set will work.
I went to home depot and bought a wall phone jack. I then took the bottom off the Madcats pedals (the Phillips screws are under the square rubber pieces which you can peel off with a small blade - common screwdriver) and you will see there are 4 wires going to the cable that normally plugs into the MC2 wheel. Pop the face plate off from the phone jack but don't throw it away and cut the cable on the inside of the MC pedal set about 2" from the grommet. You can pull the grommet out of the slot and discard the cable. Carefully strip the insulation on the 4 wires (Brown, Yellow, Blue and White). I've done the hard part, which took me about 5 hours so here are the correct wire color match-ups. The phone jack has Green, Black, Red and Yellow wire hook-ups. Connect the MC-Yellow to PJ-Green; MC-Blue to PJ-Black; MC-Brown to PJ-Red;MC-White to PJ-Yellow. Now you can plug in the phone wire connection from the wheel into the phone jack and try out the MC Pedals. Much better? What I did next was cut a hole in the back of the MC pedal case (make sure it is not in-line with where the bottom plate weight goes. I used a hole saw just smaller than the phone jack and then used a razor knife to form a good fit fro the phone jack. Remember the face plate? Get yourself a good pair of sturdy Scissors and cut around the circle on the face plate. Now put the phone jack in the hole you made from the inside of the pedal housing and snap that little disk you just cut out from the face plate onto the phone jack from the outside of the pedal base. Now you may want to glue the phone jack in place on the inside of the pedal base just so it stays put. I used epoxy putty because it kneads like play-do and is easy to push on place. Also it sets up in just a few minutes. Now just put the bottom plate back on the MC pedals and put the screws back in. You will find that the MC pedals do not have the same problems that the Microsoft pedals did like the sticking throttle problem and they are much more responsive.
May 20, 2009 | Microsoft Wireless Race Wheel 2 for Xbox...
Cables Unlimited InterAct Racing Wheel V3 (ACC-SV280) Wheel And Pedals Set Logo
261 people viewed this question
Top Cables Unlimited Video Game Consoles & Games Experts
James Wishart
Are you a Cables Unlimited Video Game Console and Game Expert? Answer questions, earn points and help others
