Question about Panasonic PT-AE900U Multimedia Projector
Blurry and discolored
There is a blurry spot about three ft. in diam. in the middle of my picture on a 120 in. screen. Also discolored in the same area. What can i do to fix this problem? The projector is only about 6 months old with only about 300 hrs.
blurry and discolored - smile.gif smile.gif I have this projector (out of warranty) and it had the same problem. I traced the problem to the green polarizer which is a glass sandwich assembly right in front of and attached to the green LCD panel frame, though I suppose it could happen to the red or blue. There is a plastic membrane laminated to the glass on both sides of one panel or slide which is the actual polarising element. The element that faces the opposite panel in the sandwich was melted in a 1/4 inch circle in the center of the polarizer. It looked like wavy ripples on a puddle when viewed under a stereo microscope or 10X loupe. With the LCD block removed you can hold the assembly up at an angle to a light and inspect each polarizer for damage. I can only speculate about the cause of this condition. My best guess is a very light paused signal left for an extended period that heat stresses the plastic layer like the sun through a magnifying glass. Anyway, I carefully removed the polarizer per instructions in the service manual, pages 63 & 66(available online), and replaced it with a new one (part #TKGP0029) at a cost of $75 and my time which was about 3 hrs. This procedure isn't for the faint at heart or the clumsy! You need a steady, meticulous hand, patience, and very good mechanical and preferably also electronic abilities to attempt this. The defective polarizer must be carefully and slowly pried away from the small strips of double sided tape that secure it to the LCD frame with an exacto blade or fine jewelers screwdriver, and the new one replaced with fine tweezers and gently and firmly pressed onto the tape. A stereo microscope or 10 power loupe really helps with the process. Make note of the orientation of the two colored dots on the polarizer, green in this case, before removing. Otherwise, send it to an authorized repair facility or remove the bulb and find a used "good" projector on eBay or craigslist that needs a bulb. The cost might be the same, occasionally $300 if you're lucky.
This symptom may also be caused by other related problems, but that's my story and I'm stickin' to it! Hope this experience helps in some way. smile.gif
Woody
Posted on Apr 06, 2008
  • 682 Answers
Clean lens-adjust colour and tint from main menu.
Posted on Mar 16, 2008
I got blurry shots around the middle of photo
Hello, On the LCD screen or on the photos ? Do you mean blurry SPOTS ? Is the lens scratched or dirty ?
Jan 22, 2013 | Sony Cyber-shot DSC-W55 Digital Camera
I have a hitachi 50vs69a with 2 yellow spots in the middle of the t.v when powerd on.....black when off. these spots almost resemble states...there is also blue splotches in the middle of these spots. any...
Yes, if the spots are round or teardrop it may be burnt picture tubes.
Easy to confirm this by covering lens of tubes one at a time with set on and see which removes the blotches.
What happened in a lot of these sets is the set arcs and burns a black dot dead center in one or all three of the screens of the picture tubes used--fatal case and permanent.
Mar 14, 2012 | Hitachi 50VS69 50" Projection HDTV
MY HITACHI 50GX30B HAD BLURRY VISION LIKE
Sounds like the convergence board, try replacing the STK voltage regulators and any resistors that may burned or discolored. This problem is causing the power supply to shut down probably.
Mar 13, 2010 | Hitachi 50GX30B 50". Rear Projection...
Picture has a blurry bottom. The bottom 6 inches is blurry, if there are words its hard to read. There is also a red tint arc in the middle at the very bottom of the screen.
If picture looks 3d and will not adjust (select convergence in the customer menu) one or both of the STK-392-120 CONVERGENCE CHIPS ARE BAD.
What needs to be done if this is case is to replace both chips and any of the 6.8 ohm protect resistors around them that are discolored or bad---I did one of these sets a few days ago--repair takes about a hour.
The parts for this repair cost less than 20 dollars if you buy them on EBAY. The real question is are you able to do the repair yourself?
If yes, I can give you instructions--it involves getting at the chips--unsoldering all 18 pins on both--checking the resistors around them etc.
If you cannot do this repair--shop around your area--most shops get 300-400 for this repair---the one I did the other day I charged 250 total---in home parts, labor, house call--everything.
MAKE SURE IF YOU GET SOMEONE TO DO THIS THEY REPLACE BOTH CHIPS! Some idiots will come out and just replace one chip---the set is going to have the same problem in a few months----
Once both are replaced and the set adjusted--it will not have this problem again for 5-8 years.
Clearly I do not know if you can do this repair---I am here to help people-IF YOU HAVE ANY QUESTIONS OR NEED HELP---do not hesitate to ask me here .....
Regards, SD TECH
Oct 07, 2009 | Philips 55PW9383 55" Rear Projection...
Blurry screen on 50in Hitachi LCD
Sounds like you need a bulb replacement, if you watch tv a lot ave life is about 5 years
Sep 14, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Sony 60" LCD projection TV has yellow screen discoloration
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
Feb 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blurry screen appears as 3d with blue discoloration
Go into the convergance mode and clear it up ,ther is also three knobs behind the press board one will adjust the overall background
color ,thew others focus.
Feb 08, 2009 | Hitachi 51F500 51" Rear Projection...
I would suggest to try to get this TV fix while still under warranty. Normally the manufacturers give one year.
In regards to the discoloration, there is not much you do but to let the Sony authorized repair center knows about it so they can fix it. Ask them if their work is guarantee as well for how long.
Good Luck.
Feb 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Panasonic PT-AE900U Multimedia Projector Logo
572 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
