Question about Kenmore Dishwashers
My dishwasher stopped in the middle of a cycle and is full of water. Breaker is good and power is at dishwasher but will not restart and no lights will go on when buttons pressed? Any ideas?
I replaced a thermal fuse located under the control panel. A power surge likely the cause due to a storm passing thru town.
Posted on Nov 17, 2009
Testimonial: "quick response and accurate diagnosis"
Dishwasher has no power and water is still at the bottom. What's the parolem
Could be something as simple as your circuit breaker which is usually seperate from other breakers, so always look for the easiest solution first. If you have no lights, if your dishwasher is like most with indicators for cycle selection, then it is a power issue. If no noise at all, sounds like no power.
Good luck,
Asthma-Free-Home.com
Nov 16, 2014 | Hotpoint Dishwashers
GE dishwasher with tactile board. Worked fine until special fingers caused issue? Now only the CANCEL and timer light-up when CANCEL pressed. Pump runs to drain for 2 minutes. Stops. NOTHING. Dont see...
This should help: PDW8000 series: press the resetbutton once. This will cancel the washing cycle and pump the water out of themachine. PDW9000 series: open the door aninch and wait for the machine to stop. Touch the reset button to cancel thewashing cycle and reboot the panel.
According to the GE Owner's Manual for the PDW9000 series only: If the"start/reset" light is flashing, close the door until the water pumpsout (this takes approximately 2 minutes) and the light stops flashing. When thelight stops flashing, the dishwasher can be reprogrammed and restarted. If the machine is unresponsive, killthe power to the machine by turning it off on the wall switch (if applicable)or turning the circuit breaker off. Leave the power off for 30 seconds,then turn the power back on. If thatdoes not work here is the repair info: Get into the service mode by pressingkeypads #8 and #4 for 3 seconds. Then reset from service mode. LINK to SCHEMATIC
Mar 28, 2011 | Dishwashers
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Hotpoint sdw dishwasher
It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
183 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
