Question about Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Laptop-side bar for web camera does not side back as before. It is obstructing view on left side of my computer.
  • kudakthiyilc Nov 26, 2009
    We are not able to open the camara in our laptop.How to go about it?
I solved the problem by searching for information on the Toshiba web site and finding the way to do it. Thankyou.
Posted on Nov 16, 2009
Why is my toshiba satellite c655d-s5200 screen is black and i can faintly see
Okay. Got a bright flashlight, and some tape?
OH I'M JUST KIDDING!
Primer;
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED's.
Light Emitting Diode.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch. Average length is almost as long, as the LCD screen is in height,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 11 photos ]
A screen Inverter converts the power from the laptop, for the LCD screen.
The Toshiba Satellite C655d-s5200 uses LED's for the Backlight, and No screen Inverter,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~C655D-S5200/
Which narrows your problem down to two possibilities;
A) Problem with the video cable
B) Problem with the LCD screen.
I state LCD screen, because you won't be replacing the LED backlighting. You have to buy the entire LCD screen assembly, as shown in one example above.
(Example is shown for reference, not advertising. You may find a better deal from a reputable dealer, also)
Video Cable:
The Video Cable is attached to the motherboard, under right about at the number 6 key, on the Keyboard.
It then goes across to the Left Hinge, and up into the Display Assembly.
From there it goes to the back of the LCD screen.
From everyday normal opening, and closing of the laptop over time, the video cable may become pinched, and pulled on.
This can create a loose connection at the motherboard side, and/or LCD screen side.
It can also cause damage to the video cable. If the sheath of the video cable shows visual apparent signs of damage, the wires inside may be damaged also. (Stretched/Broken)
Laptop off, ALL power removed, (AC adapter {Charger}, and Battery), I suggest checking the motherboard side connection first.
A visual inspection will Not do. You need to physically see, if you can plug the motherboard side plug of the video cable, into the connector on the motherboard.
A loose connection that is not apparent to the ***** eye, is all it takes to have a problem.
You can click on any photo to enlarge,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-2.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-3.htm
Stop on Step 22. Access to the motherboard side of the video cable.
A word on the Keyboard Cable, and it's connector on the motherboard; (Steps 9, 10, and 11),
The Keyboard Cable stays with the Keyboard. It removes from the motherboard connector. The Keyboard Cable has NO plug, or connector on the motherboard end.
The Keyboard Cable is a FFC. Flat Flex Cable.
It has flat gold plated contact strips on the motherboard end.
The motherboard connector is a ZIF connector. Zero Insertion Force.
In Step 11 you can plainly see this connector.
Has a large white rectangular BODY on bottom.
The smaller rectangular shaped piece on top is the Locking Bar.
The Locking Bar does NOT completely remove from the Body.
If it does it is broken, and means motherboard replacement.
Hence why I am being so detailed.
I am sure you use great finesse, but wanted to advise you in advance of the 'danger'.
The Locking Bar is moved towards the LCD screen, and as advised about 1 millimeter. ( -> O <-)
There are Tabs on the Locking Bar. One on each side. Usual procedure is to use your thumbnails on these Tabs, and ease the Locking Bar forward.
Now gently tug on the Keyboard Cable. You may have to gently move it side, to side, to break the Keyboard Cable loose. They sometimes get stuck over time.
Pretty stiff? Better check to see if you have the Locking Bar fully unlocked.
The Keyboard Cable MUST go back in the same position, and through the same plastic Latches and Channels.
(As do all the cables, or you may pinch them, and also will not be able to get the laptop back together correctly again)
Make a mark on one side of the cable, (Away from the gold plated flat contact strips), and a matching mark on the ZIF connector of the motherboard, if you need to.
You can slip the Keyboard Cable back in, Ram Memory, DVD drive, and Battery, and reconnect the AC adapter, to see if this was the problem.
Still no?
Check the LCD screen side connector of the video cable. Is it tight?
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A665-A665D-A660-A660D/remove-replace-lcd-screen.htm
LCD screen connected, turn the laptop on.
Was this the problem?
No?
Even if there are no apparent signs of damage, you may wish to take the video cable down to the nearest 'Mom and pop' computer store, and ask them to check it for continuity. This way you can see if any wires are broken inside. (Labor charge may be free to $5)
(My thinking is if you go to a large computer repair shop, they are going to want to repair the laptop, or sell you an LCD screen, or a new laptop. "Oh that old thing? For 2995 I can put you in the seat of this baby!" )
Or since the video cable is very economical, you may wish to just replace it.
Just one example from a quick search,
http://www.ebay.com/itm/Toshiba-Satellite-C655D-6017B0265601-LCD-Video-Cable-Genuine-OEM-Laptop-Tested-/290753862740?pt=US_Video_Cables_Adapters&hash=item43b247dc54
[Black end on right is motherboard side, gold colored end on left is LCD screen side ]
Video Cable ruled out your problem is the LCD screen, or to be more specific, the LED backlighting.
Replace the LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 28, 2012 | Toshiba Satellite C655d-s5200 15.6" Screen...
In my Toshiba L640 laptop i can't open the Webcamera how can i open the web camera of my Toshiba L640 ,answer me faster
go to my computer. with drives and CD drive, there also the web camera. open it. if not, see the programmes. there must be a programme related to your webcam. If not, your system have no web camera driver. go to the toshiba site/ support and download web cam driver, install it and enjoy.
Aug 28, 2011 | Toshiba Satellite L640D-ST2N03 Laptop...
I recently got a toshiba satellite computer and it has no hard drive and i dont know what i need to do next. i know i need drivers and such and recovery discs, but where can i get them and everything?
This model Toshiba Netbook came with a 240Gb hard drive and Windows 7 Home Premium (64bit)
You can view the full specs from this WEB site.
http://us.toshiba.com/computers/laptops/satellite/L450/L455-S5046/
You can download theRecovery CD and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Aug 06, 2011 | Toshiba L455-S5046 (2500470) Netbook
Install drivver web cam toshiba satellite L510 in my laptop
Enter "csd.toshiba.com" in your address bar.
Select "Download"
Select "Laptops" then "Satellite" then "L510" and click "Go"
On your keyboard press "Ctrl" and "F" and type the word "refine"
To the right of that there will be two drop down menus. Using the menu to the far right click the down arrow and scroll down to select the "camera" option.
Click the "Web Camera Application" link
When prompted for "Save as" select the 'desktop'
When the file is completed, double-click it and conclude setup.
Mar 06, 2011 | Computers & Internet
How do I use the integrated web cam on my Toshiba Satellite laptop?
There are several ways you can use the camera on your toshiba laptop.
1.) Use a program such as Skype or Windows Messenger; these programs will only use your web camera when you video chat with someone else over the internet.
2.) Alternatively, most Toshiba laptops come with a built in program that you can use to activate the web camera, and you may even be able to record videos and take pictures. This program is usually found in a toolbar on the side of your screen. To use it, move your mouse cursor to the left side of your screen, and something should pop out. The camera can be activated from there.
3.) If this does not work, clicking on the start button (the circular windows logo found in the bottom left corner of the screen) and typing in camera should bring up a program called 'camera assistant.' Clicking on this should also start up the camera software.
Feb 28, 2011 | Toshiba Computers & Internet
Hi! I bought a 2nd hand Toshiba Satellite L300 online. The camera used to work fine before, but after converting to another OS (Windows 7 Professional 6.1.7600 Build 7600) the camera won't register any...
hi! try this one maybe it could help. I used this on my Toshiba L300 Laptop on Windows 7 Ultimate and it works fine. http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_camera_chicony_TC50040800A.exe
Dec 04, 2010 | Toshiba Satellite Pro L300 Notebook
Hello, i have a toshiba satellite laptop with wireless connection. i recently purchased a netgear dgnd 3300 modem/router and have configured it successfully. i have connected my xbox 360 wirelessly and...
Go to the laptop. Open Internet Explorer. In the address bar type
192.168.0.1 or 192.168.1.1
Do you see the new Router or the old one. This is where you set up the connectivity and password. Disconnect your X-Box when setting up the Laptop.
Tips, tricks and videos on setting up in the link.
Home networking explained part 5 Setting up home router
Apr 12, 2017 | Toshiba Satellite M50 Notebook
I need index web camera driver software Toshiba Satellite L305-s5883 Built-in camera has error message. need to update driver I think.
Go to start, programs and windows update and click on custom and and on the left side you will see hardware, click on it, it will find the up to date driver for you.
May 27, 2009 | Toshiba Satellite L305-S5883 Notebook PC
Camera assistant software not working
Please help.... to troubleshoot this problem re: toshiba satellite L310 web camera doesn't work. the light blue color sensor display but appear only black screen.
Jun 23, 2008 | Toshiba P205-S6267 Notebook
Toshiba Satellite Pro L300 Notebook Logo
508 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
