Question about Microsoft Xbox 360 Console
The cross pad on the controller is moving on it's own.
  • 127 Answers
Inside the controller their probably is something loose. i dont advise this without a tech expert near you, but if you choose to, take the controller apart(carefully) and check for loose/ damaged or bent parts, and take it to a game shop like EB games if you cant fix it. or you could buy a new one.
Posted on Nov 15, 2009
When i hit right on the D pad it moves left how do i fix it?
DIY Fix the d-pad on the Xbox 360 control pad (more than just
www.instructables.com/.../DIY-Fix-the-d-pad-on-the-Xbox-...
InstructablesOkay, first things first: I find the d-pad on the 360 wireless controller to be a mushy mess. ... hits the contacts on the circuit board) and the bottom of the d-pad's contact ... All we're going to do is add a very thin layer between the membrane and the ... controllers, pressing right will for example register as down-right, and so on.
Weird Controller Glitch - Left on Analog is Right on the D-Pad
Dec 25, 2015 | Computers & Internet
Tip
BOWLING TIPS
<b>How To Scare The Crowd:</b> <br /> <br />Start the regular bowling motion, and let go of the ball on the back swing. The ball will fly backwards, and the crowd will jump and scream.<br /> <br /> <b>How To Throw Your Ball Down The Wrong Lane!</b> <br /> <br />You can start the ball on another track by holding down the A button, and dragging to the right as you can. The ball will go in the alley side of their own.<br /> <br /> <b>How to Amuse the Crowd When You Bowl:</b> <br /> <br />You can make the crowd laugh. Move to the sewers in your lane, turn into the opposite lane, and bowl the ball has crossed the barrier between the lanes. The ball will go by the wayside in the opposite lane, and people laugh.<br /> <br /> <b>How To Get A Special Bowling Ball:</b> <br /> You must get to the pro-level to unlock the bowling ball that has diamond designs on it.<br /> <br /> <b>How To Change The Color of Your Bowling Ball:</b> <br /> <br />When the screen goes black for bowling, hold down the control key positions in the following colors specified bowling ball: Control Pad Up Blue Ball Control Pad Right: Gold Ball Control Pad Left Red Ball Control Pad Down Green Ball .<br />
on Jan 02, 2011 | Video Game Consoles & Games
Tip
How to keep playstation 3 cool and silent
get 4 ridged foam pads dimensions 4cm by 4cm by 4cm (4cm cubed)
and place the foam pads underneath where the four rubber feet are while the console is horizontal
this will move the ps3 4cm in the air creating more room for the air intake vents on the left side (the side where the hard drive is)
since i have done this my ps3 has been silent while on cross media bar and i mean silent and barely noticeable while playing MW2
http://i813.photobucket.com/albums/zz53/fkuk/IMG_6156.jpg?t=1260908626
on Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Touchpad sensitivity: hi there, the sensitivity on my uncles HP Compaq 6720s is extreme, you can literally drop a feather on the pad and it clicks like you were tapping it, this gets extremely annoying...
GO TO CONTROL PANEL.SELECT KEYBOARD.RIGHT CLICK IT AND SELECT PROPERTIES.FROM THERE YOU CAN SET YOUR OWN PARAMETERS.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | HP Compaq 6720s Notebook
The controller cross pad is moving on it's own.
you most likely have a loose/broke or damaged internal issue, and with an expert near you should (carefully) take it apart and check for any of the above issues with the screws, buttons, etc. and i reccomend instead of doing this yourself take it to a game store like Game Crazy and have it looked at and possibly shipped or repair, or you could buy a new one.
Nov 15, 2009 | Microsoft Xbox 360 Console
Oven is beeping flashes f7. goes from push start for hi broil to low broil
HI, your key pad or touch pad is malfunctioning. most units will have a integrated touch pad. In this case, you will need to replace the entire control board, in order to restore normal functions. Now, if you units control and key pad are separate entity's, i recommend this test below to determine which is at fault.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 21, 2009 | GE Ovens
My 90 b2200 has been parked for a while...i had it aligned 5k mi ago before driving it cross country...not it pulls to the right rather hard, and when start to move it seems like the brake is still on..i...
sounds like you have a frozen brake caliper, lift right wheel off ground and remove tire, try to spin disk if you cannot then u need to remove caliper try using a c-clamp and compress inner pad and see if piston will move inward if yes check for leak and clean retry and if still doesn't work or cannot move piston in replace caliper. It most likely has rusted and seized from long term sitting.
Jul 16, 2009 | 1988 Mazda B2200
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Brake pad replacement
hay there mate
i have a 1994 volvo 850
just recently changed the rear padds
first undo the calpiper
the front will come of and also the front pad with a little cross looking clip
than take the whole rotor of to get to the back ones
the clip clips back on once you have evry think back on just the support the pins from moving
Jun 21, 2008 | 1994 Volvo 850
Wont connect to PS2
Make sure transmitter and reciever both infrared led are cleaned. If cleaned then problem with receiver, try different one if you have another.Cross them up
Sep 07, 2007 | Logitech (963320) Game Pad
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
