Question about HP Compaq d220M (829160054797) PC Desktop
Help me repair my computer with p4x266a motherboard
Computer beeps continuosly without display at the monitor and restart light indicator keeps on lit
  • 99 Answers
I think the problem is your memory,but before you replace your memory , do this first, unplug your PC,remove your memory module and clean it by using the rubber eraser,and clean the memory slot ,
Posted on Mar 11, 2008
  • jose obrero
    jose obrero Mar 11, 2008
    pls..use contact cleaner to clean your memory slot.
  • 2,427 Answers
The beeping sound is your system telling you that your memory module is bad... Take it out and get a new onem if you are not sure which type to purchase yu can have a look at the manual to see what tpye of memory you system requires ir you can take it to the store with you..
1.) open computer
2.) locate memory module
3.) remove module by pulling clips apart
4.) replace
5. thank god your done
cheers
Posted on Jan 09, 2008
Help my dell is not displaying but the front led is showing the power light on CPU but is not displaying on the monitor and i have used working RAM on the Computer but the problem is the same, kindly help...
If you do not hear a post beep sound, then you may have an issue with the motherboard and/or processor. I suggest you either take it in for repair or replace yourself
If you hear the post beep sound, then listen for the sequence of beeps. This should indicate what is wrong with the machine. Generally(Note: these may be different with motherboard and/or bios type).
  • sequential long beeps indicate RAM issues
  • 1 long followed by two short indicate a display adapter issue
Mar 23, 2015 | Dell (E210882) Motherboard
No display on monitor,No cd drive ejecting but cpu fan is running and power on led light is in green in mother board ,No beep sounds Can anybody Know the problem of my motherboard? Help me guys
Hi
This is a difficult one without knowledge of specifics. However here goes. The absence of beep codes would indicate that the motherboard is getting through its POST routine OK, although some boards give a single beep when the POST is completed and the absence of this beep indicates a problem on these boards.
The CD drive not ejecting can be that there is no power to it. Does it have a light on it during POST. If so it is probably just stuck. Try using a straightened paperclip in the very small hole in the fascia plate.
Now to graphics, I am sure you have checked that the computer to monitor cable is firmly connected at both ends, and if the computer has two graphics ports, that it is plugged into the correct one. Does your graphic card have a separate power supply, if so is this securely seated? The way to test the graphics is to connect another monitor that is known to work into the computer and seeing if you get a picture. If you do then the monitor you are using is faulty.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Computers & Internet
"I tried to install another internal HDD + another 256 RAM (both of them are used) to my computer, operating XP with an ASUS P5P800S motherboard. When I ran the system, the new device was found by the sys....
The hard drive would not show up until you initialize it in the control panel. With everything off the motherboard you should get some post beep. Put the ram back and try again, the next thing to install is the video to see if there is any indication of function. Keep adding things back. If there is no post beep with just the motherboard then you need to test the PSU and if it is OK then CPU or motherboard is bad.
Sep 26, 2014 | ASUS P5p800s Motherboard Intel 848p Lga...
No display
first check wether ur monitor light is blinking if not there is problem with ur display or the power is not correct if all this is ok and ur monitor light is blinking remove the cpu cover remove the memory and restart ur computer in new motherboards muzzers are fitted on the motherboard or else connect a buzzer to the speaker pin iin the frontpannel and restart the computer with no memory you will hear 2 long beeps it means the memory is not present then clean the memory pins eith an erasor dont use any metalto clean the memory insert the memory in the nemory slot if you hear again the long 2 beeps it means the memory is fried if you hear one beep means the memory is fine and the system is working still no display means then check if the display card is addon or motherboard built in if addon change the addon card if built in contact chiplevel service person also check the ponit cable connected firmly to the computer with 2 screws on the cable tightened to the cpu
Oct 14, 2010 | Dell OptiPlex 360 Desktop Computer
Hi, i have Samsung SyncMaster 225BW monitor and while using Microsoft word it stop working. On off button blinking with blue light.. However when i plug/unplug the video cable nothing happens. Regards...
There r problem with your CPU not from Monitor might be any hardware failure at that moment.Pls restart the system after that if display is coming or not if display is not coming might be RAM chip is faulty replace it with goods one.If display still not coming then problem with your Motherboard.pls get it repair by vendor.
Nov 17, 2009 | Samsung SyncMaster 203B LCD Monitor
I have a toshiba satellite p305d-s8828 laptop and have 19dc @ plug going into main board and 19dc on motherboard. Is the motherboard fired? And no power on computer.
Since you have measured the voltage on the motherboard I must presume you are saying there is no power "indicator light" on computer. If this is not the case please clarify. If the light is absent please test the battery as these laptops are not designed to work without a battery or with a dead battery. Operating without a battery can spike the motherboard or other components and cause failure due to overvoltage. If you do have a power indicator light then next observe whether the bootup is proceeding with a beep after the POST (power on self test) and whether you can hear the movement of the hard disk drive... possibly indicating failed LCD display or display drivers/setup. Press F8 after the POST beep to get to safe mode display drivers.
Oct 07, 2009 | Toshiba Satellite P305D-S8828 Notebook PC
I have Intel DG31PR series motherboard with 2GB
The number of the beeps is a specific post
error code and should help diagnose. e.g.:
my computer has 3 beeps to indicate RAM
failure. Note the beeps and find in your manual
or from Intel support.
Here's some help to get started:
Beep Codes
Intel Support
Jul 12, 2009 | Intel DG31PR Motherboard
Data is not sent to the monitor
The first thing to do is to pay attention for "beep" when your press the power button (or the reset button) to turn the computer on or reboot it. The beeps that a PC makes tells you a lot about the state of your computer. I couldn't quote for you the exact beeps to listen for, but your manual for your motherboard may tell you. Different beep pattersn tell you what is wrong with a computer.
I think for many common motherboards it is something like 4 beeps to tell you the graphics card has failed. Don't quote me, but that is at least along the lines of how it works if not the exact number.
If you're getting no display after starting your computer make sure you hear one beep. Then, listen for other activity. If you're computer has a floppy drive, listen for the 'floppy seek'. Otherwise, listen for hard drive activity. If it sounds as though there's activity along those lines but still no signal/display on the monitor perhaps check the cable between your PC and the monitor. Never hurts to just make sure the monitor is turned on of course.
If your monitor is on, and the cables are connected securely I wold restart the computer again and check for the beeps. I would be certain to count them and check the manual. Your graphics card may have failed if you hear abnormal beeps (more than one as one is usually the healthy indicator). If you hear no beeps then the PC is not even getting in as far as testing it's devices and could quite possibly be a motherboard failure.
Dec 19, 2008 | Dell OptiPlex GX110 PC Desktop
Alarms
Hello, find the BIOS Beep Codes at http://www.amptron.com/html/bios.beepcodes.html and try to find your problem. It is not a software or Monitor problem. It could be RAM or Video Card failure
Aug 04, 2007 | Biostar M7VIZ Motherboard
HP Compaq d220M (829160054797) PC Desktop Logo
967 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
