Question about Craftsman Garden
I have CraftsmanLT1000 lawn tractor, Smokes heavily.
I have CraftsmanLT1000 lawn tractor, it starts well and seems to run fine initialy but then starts to smoke a lot. Any ideas? Tractor is approx. 6yrs.old, it has 18hp ohv engine (Briggs&Stratton)
  • 486 Answers
Many times a dirty air filter will cause this on this style of engine. When the filter is plugged, it creates a 'rich' fuel condition, and the engine smokes heavily, the excess carbon is drawn into the air filter, and plugs it even more.
check spark plugs, air filter, fuel filter, choke linkages (for full choke/no choke operation) and crankcase oil.
Crankcase oil can become fuel contaminated, thus overfilling the crankcase and filling the crankcase breather with raw oil/fuel, and this is drawn into the air filter, plugging it, and starting this senerio.
If there is fuel in the crankcase oil, drain completely, and refill with fresh oil. Then you need to look towards the carb for an inlet needle sticking, broken, worn.
Posted on Nov 16, 2009
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Lawn mower engine smokes
check the oil and see if it smells like gas the needle valve in the carb can leak and drain the gas into the crankcase
May 11, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you adjust valves on a craftsmanLT1000 19.5hp
Go to you tube On line on page adjust valves craftsman 19.5 mower. Your get alot choices.
Mar 08, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Carb blows black smoke and runs bad but run good with no air filter or with a new filter
The old filter must be clogged. So if it runs ok with a new filter do you still have a problem?
Apr 16, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
First check the oil, not only the level but the smell
if its overfull and it smells like gasoline then the problem is that your carb is dirty or the float is sticking and flooding the engine with gas. If the oil is at the correct level then the problem is more likely the valve stem seals, as the engine warms they leak. I presume you have checked the airfilter is clean? The choke is comming off completely when you move the throttle cable? The LT 1000 is the entry level rider in the sears line. The engine usually starts wearing out in about 50 hours use. Remember the sweetness of low price is long forgotten with the bitterness of low quality!
Nov 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
17.5 h.p. b/s craftsman tractor oil pushes into carb. smokes bad!
Make sure it's not overfilled with oil.
if this is not the case, then you have excessive blowby, which is what blows past your rings when the air/fuel mixture ignites. there is only one explanation for this, faulty rings, and that's what it sounds like to me. the blowby forces the oil into the vent leading to the filter, and back into the cylinder, where it burns, creating blue smoke.
Apr 14, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
460 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
