Question about InFocus LP70+ Multimedia Projector
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
  • wizbaugh Dec 05, 2009
    This is an Optoma EP721, would this be the same?
  • 2,237 Answers
Is it an optoma or an infocus? if it is the infocus, it needs to be replaced. however, to replace it, you need to remove the entire optical engine. now off of that, remove the clorwheel and clip, the main board, and the tunnel (on this model it is called an integrator rod) assembly. to get that out, remove the 3 tap screws and the large screw. once you can slide it out, remove the foil from the front, slide out the inside tunnel assembly, remove the clip, then the tunnel. because the clip is an exact fit, you cannot have anything on the tunnel that increases the size. reverse the instructions to reassemble (but you will need to replace the foil with a new one). warning: you now need to realign the tunnel using 2 of the tap screws. if you have not done this before, it is very difficult and dangerous, as you need to have the projector powered on and the screws are way inside next to the power supply. there is a risk of electrocution and damage to the projector. best bet- send it in to an authorized infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Dec 01, 2009
  • jasbo
    jasbo Dec 09, 2009
    it is not the same as the optoma. it was under the infocus lp70+, so i assumed it was. but the problem is still the light tunnel. the installation is different.
    Scholar:
  • 167 Answers
This is a common problem with InFocus projectors!
The Light Tunnel / Pipe has begun to collapse.
The Light Tunnel is a series of 4 first surface mirrors that make up a square box approximately 30 mm long with open ends. This part is mounted within the die-cast optical assembly directly behind the color wheel.
This tunnel is a conduit to concentrate and couple the light energy from the color wheel to the first objective lens in the DLP engine. Is is held together with an adhesive that breaks down in time from the intense heat causing the glass mirrors to expand and contract with these extreme temperature variations.
(Cutting to the Chase now) The Light Tunnel needs to be replaced. This is rather tedious on the LP70(+)
And most likely a service facility will just replace the DLP engine. However depending on your skill level you may be able to figure it out and perform the repair yourself... It can be re-glued with a high temp adhesive (not with crazy glue) and work just like new!
I would suggest an "EASTMAN" Hi-Temp adhesive.
Good Luck!
SagerTronics
Posted on Nov 29, 2009
  • David Hammack Sep 19, 2013
    I have a similar issue on my optoma gt700. I took it apart to inspect the light tunnel but it appears to be okay. Any other possibilities?
Parts illustrated breakdown
If it is the lens you have other problems that would let it get that hot. Can't be sure, but I would first check the bulb to make sure it has not smoked. If so it must be replaced. When handling the bulb let it cool down or you can get severly burned. Never let your skin touch it or the oils on your skin can damage the bulb. I usually use a t-shirt or something to wrap it in while handling it or you could just wear cotton gloves.
Aug 30, 2014 | Optoma HD20 DLP Projector
Dark spot
These bulbs are very sensitive to contamination. When installing a bulb, do not touch it with your fingers, as this will leave your natural oils on it and that will become a hot spot and burn out the lamp.
Use a clean piece of toilet tissue when installing the new lamp to eliminate the above.
Jan 11, 2014 | Sharp XR-10X Multimedia Projector
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
Jun 30, 2013 | Sharp XR-10X Multimedia Projector
InFocus X3 plastic lens
If you still have the owners manual there should be an 800 number or some sort of customer support for it. Unless it's really old that is your best bet for the internal pieces
Nov 23, 2012 | InFocus X3 DLP Projector
Infocus IN24 Projector has large Dark Grey/Black Spot in the middle of the image.Lamp has 600 hours,Installed my spare "NEW" Lamp,still the same,Bulb makes no difference.Was watching a movie...
There is a lens(looks like a small magnifying glass) made out of plastic that the light shines through to focus the light on the mirror before it hits the DLP chip, that lens is Melted in the center. I unfortunately had the same thing happen to me, and I am unable to find a replacement part.
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
There is a large dark spot in the lower center portion of the projection area, I have cleaned the external lense and changed the bulb but the dark image remains.
if the spot is circular, check the lamp itself. if it has a flatter edge, chances are your light tunnel has collapsed and needs replaceing. it's not that old, so dell might repair it. but they might replace the entire optical engine, as they may not sell individual parts.
Dec 02, 2009 | Dell 2200MP Multimedia Projector
Dark spot issue.
Its an acrylic condensing lens inside the light engine that has melted/warped. You have to pullout the entire light engine then disassemble the optical light tunnel to get too the lens. Then you need a lens-smith to cut a new lens because Infocus won't stand behind this design flaw. Its really a shame on Infocus!
If you need more info contact us here: click here
Sep 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
Wonderwall projector has black spot in middle of screen
Aug 08, 2009 | InFocus LP70+ Multimedia Projector
Projector problem
if it's an lcd, the fly-eye lens might be burnt. return it.
Nov 29, 2008 | Office Equipment & Supplies
HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Jan 05, 2008 | HP VP6121 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
756 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
