Question about Kenmore Refrigerators
How do you get to the screws to tighten the handles on a side by side ref handles
  • 585 Answers
Each handle should be two pieces, the decorative insert can be pried out of the case metal part to expose the screws.
Posted on Nov 15, 2009
How to tighten faucet handle on the anabelle CA87003SRS
There is a set screw on the handle usually has a tab over it make sure the handle is properly flush to the base( i always loosten set screw take handle off make sure flat side of stem ( what handle slides over) is where the set screw tightens against . put the handle back on make sure it is as far towards the base of the faucet then take your hex wrench and tighten it down
Sep 03, 2014 | Plumbing
The handle of my side by side Kitchen Aid refrigerator is loose. The model number is KSCS25INSS00. It has circular open holes on the handle, no screws? How do I tighten it?
Use an allen wrench (hex) to remove loosen the set screws in the two handle holes. Once removed, tighten the mounting lug. Replace the handle and tighten the hex set screws.
May 21, 2010 | KitchenAid KSCS23INSS Stainless Steel Side...
Handle of refrigerator is loose. How can you tighten it?
Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Oct 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
One handle is loose-how can I tighten it
shoulb be screws under cap on handle remove and tighten that should do the trick
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loose door handle
I just FINALLY fixed mine...  Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door).  That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Door Handle repair
The fastner must be loose. Remove both set screws remove your handel. Then tighten the fastner. reinstall the handel and tighten your set screws. let me kniow if this helps
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
49 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
