Question about ViewSonic VA720 17" LCD Flat Panel Monitor
View Sonic VA720 monitor goes out after power goes
View Sonic VA720 monitor power goes out within about 15 sec. after plugging in power cord, the green power light go out, can you help? Ichecked the power supply its good.
Larry
Replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Posted on Nov 15, 2009
PROBLEM IS VIEW SONIC MONITOR WERE OSD LOCK
osd lock is on screen configuration menu (on screen display) to clear an osd lock in your view sonic you can try this step
1.disconnect power cord
2.press and hold button 1
3.plug again your power cord
4. press your power button while still holding button 1
hope it help you
May 12, 2011 | ViewSonic E70f 17" CRT Monitor
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue...
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Nov 07, 2010 | ViewSonic VA1930WM LCD Monitor
Viewsonic va720 monitor flickers / goes a little dim. wiggling the power cord often helps.
then change the power cord...there may ba loose connection...or the pins int he cable is not getting full power
Dec 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
View sonic g220f
If both ends of the cable are plug in type, any monitor cable with a 15 pin D connectors will work.
Search internet for VGA cable.
Jul 30, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
Ac power cord for HP vf51 flat panel monitor
Good Day Tricia,
I had to pull up you owner's manual to get the spec's on your cord, so if you need the manual follow this link:
http://h10032.www1.hp.com/ctg/Manual/bph08231.pdf
Anyway after reading the spec's you need an AC-DC power supply that outputs 12volts at 3.3amps. What makes this difficult to find is the 3.3amps, most aftermarket power supply only go up to 2amps. So what's next? Well you can order directly through HP at this link:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=P4824A&HP_model=&modname=HP+vf51+15-inch+LCD+flat+panel+display&template=main&plist_sval=Power+Cord&plist_styp=subcat&dealer_id=&callingsite=&strsrch=&keysel=Power+Cord&catsel=%3F
If you do this make sure get part 8121-0740 if you live in the states, or part 8121-0731 if you live in europe.
The only other suggestion I can give is to bring the monitor into a radioshack and see if they have a 12VDC 3.3AMP (you can get a universal with higher amperage if needed, the monitor will only draw the 3.3 it needs even if it is supplied more) and the reason I say bring it in is so they can match the size of the plug that goes into the monitor, as there are about 20 diffrent diameters's. Again the problem you may have is finding one with a high enouge amperage.
I hope this helps
Good Luck
Jul 01, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
In my 15" view sonic
If you don´t have any mechanical problem with the push botons, try individually :
Power Off the monitor and press the "menu" switch, over 20 sec after the power in turned on!
v15307086
Jun 07, 2008 | Gateway FPD2275W LCD Monitor
Va720 view sonic monitor
To plug out the dont need to remove any screws only by applying a little force you are able to pull the cable out.
Apr 06, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
359 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
