Question about Craftsman Garden
My gas blower starts , will not keep running. i have to keep messing with the choke for it to keep running.
    Problem Solver:
  • 17 Answers
Most common causes are:
1. plugged gas filter
2. gas tank vent/breather plugged
3. dirty carburator.
4. this also cold be casued over time by worn out piston rings not creating enough suction for proper flow of gas.
Posted on Nov 15, 2009
How do you start it?
I means "ON" and o means "OFF"
choke should be closed to richen the fuel mix to start open it slowly after it starts and runs
also note most (2cycle) gas powered leaf blowers require a gas/oil mix to run properly , straight gas will destroy blower motor
Apr 15, 2015 | Garden
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
BLOWER WILL START WITH FULL CHOKE, BUT SHUTS OFF WHEN TRYING TO REDUCE CHOKE.
I'm having the same problem. My suspicion is the carborator requires gas/air mixture adustments. This requires a special carb adjustment tool - called a Long Single D Tool. I will try to have my fixed very soon - 1 week...I'll try to keep you posted.
Feb 19, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Husband put unleaded gas with the oil added due to a 2 cycle engine, now it won't run
not clear on the problem?
I think you mean he has to add 2 stroke oil to the gas then fill up the blower then start it but it won't start? If the mixture is wrong it wont run well if at all.
Check the spark plug has a spark (unscrew it rest it against metal body with HT lead attached and try to start it, keep clear of the lead tho don't hold it in place!! it can be shocking. Check the unit isn't flooded (very wet spark plug).
try starting it with no choke, try several times then gradually increase choke, is it try to run yet?
Jan 15, 2010 | Poulan Featherlite Gas Blower, with Low...
Mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
Blower does not stay running
Make sure you have the propper mix of gasoline and oil. If the fuel is old mix new fuel to proper ratio. Find your manual and find the low speed fuel adjustment and the high speed fuel adjustment on the engine. First, turn the screws in and count the turns so you know where you started. Return the screws to the origional position. Usually 2 to 2-1/2 turns are a good starting point if you get them messed up. If the engine runs with the choke on you have to open the high speed jet a bit, 1/4 turn CCW. Keep trying this and get the feel of the change in the engine performance. If you have too much fuel the engine will not get to peak RPM. The low speed jet works similar but you have to adjust it so the engine idles at a decent RPM. This should get you on the path.
Mar 15, 2009 | Garden
Garden Logo
204 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
