Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
I have a atat blackberry phone and i forgot my entering password it wont let me access my menu or nothing im stuck
Why is it that all of a sudden my blackberry requires a blackberry ID, and I forgot my password now so what should I do
Hi, this is due to software upgrades done OS. You can try one of the following, either do a complete security wipe, wherein u enter the personal password incorrectly, just follow the promptings, then use a different email adress, or connect to a computor, and backup yr data first, then do a wipe, but still using a different email, or enter the original email adres and click on forgot password, they will send an email to that email, which u will have to access either on the fone or computor.......
Jun 20, 2014 | RIM BlackBerry Curve 8520 Smartphone
How can i change my blackberry ID
Factory reset the phone and then you can start again.
Jan 26, 2018 | Cell Phones
Forgot myblackberry id pass word
It is wise to set a password on your BlackBerry, just as you would on a laptop or PC.
After all, BlackBerry devices are similar to small personal computers.
They contain loads of information including files, phone numbers, dates and emails.
But when you forget your password you are presented with a tough situation the device will have to be completely reset to allow you to create a new one.
Come to terms with the fact that in order to reset your forgotten BlackBerry password you will lose all of the data on your phone.
A password reset wipes the device clean as a way to protect your information in case the phone is stolen it is a tight security measure that is built into BlackBerry phones.
Type in the incorrect password. The BlackBerry will tell you how many more tries you have to enter the wrong password before it resets (you usually have between three and ten tries total.)
Continue entering the wrong password.
You may be prompted to enter the word "blackberry" a few times to continue this is to make sure that you (or a child ) aren't accidentally and unknowingly typing in the wrong password.
Allow the device to reset itself and shut down.
Try to restart the BlackBerry.
If nothing loads, the application software was removed as well and you should proceed to the next step.
If you see your normal screen, proceed to the last step below.
Connect the device to your computer via your USB cord (this comes with your phone) and load the Blackberry Desktop Manager software (if you don't have it download it at na.blackberry.com/eng/services/desktop).
https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=A2C0D61EB187AB3AFD247A852FAD3647
Click "Application Loader" then "Add/Remove Applications."
Select "BlackBerry System Software" (along with any other applications you want to download to your phone) and then "Next."
Verify the list of applications you want to download on the next screen and click "Finish." Allow the Blackberry software to reinstall.
Enter a new password under "Options" then "Password" (or the similar choice) on your BlackBerry. http://www.bbhub.com/2006/10/27/heres-how-to-reset-your-blackberry-password/
BlackBerry Username & Password
Adding an email to your BlackBerry might require you to log in to your BIS (BlackBerry Internet Service).
Some providers allow you to enter your email password in lieu of setting up a BIS account, but you will not be able to access BIS services anywhere but on your BlackBerry phone.
Once you create a username or password, it cannot be easily changed, but recovery is not impossible if you have forgotten.
To use BlackBerry's website to recover a lost password, navigate to BlackBerry.com, click on "Owner's Lounge" and log in in with your email and password.
Click on "Support & Services" at the top menu inside the Owner's Lounge. A new page will open.
On the menu choices at the left, choose "BlackBerry 101" and the click on "BlackBerry Smartphone Setup".
Click on "Email Setup" in the menu choices in the middle of the screen. At the bottom, you will see a list of wireless service providers.
Click on your provider to access their BIS Web page.
Most providers also offer this link on their website.
This will open the BlackBerry Internet Service page for your service provider. For a forgotten user name, click the link beside "username" labeled "Require Assistance?".
This will provide you with information on how to contact your provider to recover your user name. This usually requires resetting your user name.
Try to choose a user name that is easy to remember and write it down somewhere safe.
Click the link labeled "Forgot Password" to recover your password.
A new page will open with two options to have your password sent to you.
If you know your BIS user name, insert it in the top space labeled "User name".
Alternatively, you can insert your BlackBerry PIN (located inside "Options" and "Status" on your BlackBery).
Click "Request Password," and it will be sent directly to your BlackBerry.
Dec 09, 2013 | Computers & Internet
I forgot my password for my Backberry phone
just enter wrong password 10 times and phone will be wiped and delete password . remember after 6 and 9 try it will ask to enter blackberry , then just type blackberry and enter again. NOTE : these will delete all your data from phone .
Oct 17, 2013 | RIM Blackberry Curve 9320 Smartphone -...
I cant log in on my blackberry messenger,forgot my password,need to reset it
hiya try this
  1. From the BlackBerry ID login screen on the smartphone select Forgot Password.
  2. Enter the BlackBerry ID Username and select OK.
  3. Enter the answer to the password recovery question and select OK.
  4. A confirmation will display Your BlackBerry ID Password Recovery email has been sent toemail@domain.com or Instructions for resetting your password have been sent to your email address.
  5. Access the associated mailbox, locate the password reset email, and select the Change your BlackBerry ID password link.
    Note:
    The BlackBerry ID reset email will come from donotreply@blackberry.com. If the email is not found in the email account inbox, check the Spam or Junk folder
  6. When the password reset page loads, enter the New Password, Confirm Password, then clickSubmit.
  7. A confirmation message will display once the changes have been saved successfully.
  8. Moving forward use the newly created password whenever logging into the BlackBerry ID.
hope this helps
John
Sep 14, 2013 | Computers & Internet
Blackberry 8900, forgot my password to unlock the phone, so entered ten wrong passwords to reset the phone, now i cant text, call or accesss internet, Please Help! Thanks
I got this phone from one of my friend who was moving abroad. He was using airtel sim with. I inserted my vodaphone sim in it and phone got locked. i have tried using password "blackberry" but it says wrong password. I dont mind if data is lost cos its not my data. Please advice how to put this phone in use. Model- Blackberry curve 8900
Jan 22, 2010 | RIM BlackBerry 8700c Cellular Phone
Describe your AT&T BlackBerry Curve
BlackBerry smartphones support individual security passwords between four and 14 characters in length. The use of the password is designed to make sure that only the BlackBerry smartphone user can access the information stored on the BlackBerry smartphone.
The BlackBerry smartphone rejects less secure passwords, such as those composed of identical characters or those that consist of natural sequences (for example, 1234). In instances such as these, the BlackBerry smartphone will display the message The password cannot be a sequence.
Set a BlackBerry smartphone password
  1. From the Home screen of the BlackBerry smartphone, click Options.
  2. Click Security Options.
  3. Click General Settings. Note: If you are running BlackBerry® Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Change the Password field to Enabled.
  5. Display the menu and click Save.
  6. Type your new password and click Enter.
  7. Verify your new password by typing it again and click Enter.
Change the BlackBerry smartphone password
  3. Click General Settings. Note: If you are running BlackBerry Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Display the menu and click Change Password.
  5. Type your existing password and click Enter.
Turn on password protection using the Security Timeout feature Security Timeout is a feature that, after a predetermined amount of inactivity, will lock the BlackBerry smartphone automatically.
To turn on Security Timeout, complete the following steps:
  4. Set the Security Timeout field to the amount of inactive time the BlackBerry smartphone is permitted before it is locked automatically.
Note: Clicking Lock on the Home screen instantly locks the BlackBerry smartphone.
Unlock the BlackBerry smartphone
  1. Press any key on the BlackBerry smartphone to display the Enter Password screen.
  2. Type your BlackBerry smartphone password. Press Enter.
Important: If a password in incorrectly typed ten consecutive times, all of the information on the BlackBerry smartphone is automatically deleted. This is a security feature.
Additional Information When the Security Timeout feature is set for a longer duration than the Backlight Timeout feature, the BlackBerry smartphone will lock automatically when the combined duration of the features has elapsed. For example, if the Backlight Timeout feature is set to dim after two minutes and the Security Timeout feature is set for 20 minutes, the BlackBerry smartphone will not automatically lock until 22 minutes has elapsed.
Sep 10, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
I FORGOT THE PASSWORD TO MY BLACKBERRY STORM
i forgot the password to get on my blackberry wht should i do
May 28, 2009 | RIM BlackBerry Storm 9530 Smartphone
Forgotten Password - help to reset.
if u hace forgot ur password nothing can be done neither u can take backup nor u can retain data in handset. U will have 10 chances at the max to enter correct password, if done with it, the handset will be wiped out.
May 22, 2009 | RIM BlackBerry Bold 9000 Smartphone
ATT SIM CARD IN A NEXTEL PHONE
nextel runs off different frequences, it wont work. sorry
Jan 11, 2009 | RIM BlackBerry 7510
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
63 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
