Question about Brother 6-In-1 Printer/Fax/Copy/Scanner
I need to know my brother mfc printer ip address
    Sniper:
  • 59 Answers
Press menu go down to network or lan press ok or set.
choose wired lan for wired network or Wlan for wireless.
choose tcp/ip, choose ip address
Posted on Mar 27, 2010
4 Suggested Answers
  • 10406 Answers
SOURCE: Brother MFC 8860 has ip conflict
Each IP-address on a network (private in your home, or public on the Internet) must be unique; hence "IP conflict" when two devices (computers or printers or iPod Touch) try to "claim" the same IP-address.
If you have configured a "static" IP-address into the printer, change it to an IP-address that is *NOT* used on your network.
Or, find the computer on your network that is using the same IP-address as your printer, and change its IP-address and reboot it.
In order to connect, your computer and your computer *MUST* have *DIFFERENT* IP-addresses.
Posted on Sep 10, 2009
SOURCE: Brother printer and Neygear router wireless connection bad.
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Posted on Jan 11, 2010
  • 8064 Answers
SOURCE: May I know the IP
Yes we can (said Obama). Your ethernet router should display it in its list of DHCP reservations. Or if you have installed the Brother BRAdmin Professional 3 software, run it and it will show you all the machines with their local IP adress.
Posted on Sep 18, 2011
Where is IP address for the MFC-7220 printer
Network printers do not have a set IP address, you need to configure the printer with an IP address that uses the same range of IP addresses as your network.
The IP configuration is normally done through the printer's Menu on the printer's buttons.
If your are using a network IP range 192.168.0.*** that your wireless router issues automatically then select a fixed IP address on your printer above the number of computers that is installed on your network. (ie if you have 10 computers the make the printer's fixed IP address say 192.168.0.30) so the wireless router cannot issue a conflicting IP address.
When you install the printer driver on each computer then go to the Printer Properties - Port tab - click Add Port - IP port and enter the printer's fixed IP address and printer name.
Do a test print to check if your computer connects to the network printer.
Oct 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
Brother mfc-7840W not picking up wireless IP address
It is common, mainly because the MFC connection is lost to your PC. Are you able to print or scan from another wireless PC that you have? If yes, contact your network admin or router oem. If no, reset network card. Run the Setup Wireless Wizard. Make sure you have router info such as SSID, Network Security Key, Authentication Method (Open, Shared, WPA/WPA2-PSK), Encryption (None, WEP, AES, TKIP). Enter those info, it must be CASE SENSITIVE. Just in case you dont know your router info, contact your router oem.
For Advanced Users.1. Click your Wireless Icon at Task Tray2. Right-Click your Wireless Network Name3. Select Properties4. Go to Wireless Security Settings5. Take note of the settings that you have there and enter it again on your MFC
Goodluck! If you still need more assistance. Call us 1-877-Brother. :)
Jan 03, 2012 | Brother MFC 7840W Printer
May I know the IP Address of Brother MFC-490CW printer?
Sep 03, 2011 | Brother MFC 490cw Color Inkjet...
I have changed my router and my networked printer no longer works
Hello Warren !
What happened is that when you replace the router, the IP Address for your printer changed as well. Your network printer connects to your computer through a number called the "IP address" wich is assigned by your router, since you replace your router, the new router assign a new Ip address for the printer, so you will need to change that IP address on the printer driver on your computer as well.
What you need to do is print a configuration report directly from the printer to figure out what the new IP.
When you have this number ( it will look something like "192.168.0.1")
you need to go to "printer and faxes" under control panel, make a right click on the MFC-465 icon, go to properties, then go to the ports tab a click on "Add Port" select Standard TCP/IP and type in the new ip address.
This should reentablish the communication between your printer and computer.
Good Luck
You can contact me directly here:
eliteprintersolutions@gmail.com
Jul 15, 2010 | Brother MFC-465CN InkJet Printer
My MFC 685 CW will not print.
Hello ,
First, we will have to make sure the printer is properly connected to the network
  1. Go to your printer.
  2. Press “menu” and scroll down to network, then WLAN
  3. Go to TCP/IP
  4. Go to IP address. Make sure there is an IP address here (not 000.000.000.000). Change the last 3 digits to “050”
  5. Change the boot method to “static”
If your IP address is not a valid one (all zeroes) or is an APIPA address (starting with 169.254.#.#) you will need to run the wireless setup wizard again as the machine is not properly connected wireless
If you had a valid IP address before changing anything, it means that the printer offline is caused by the computer not being able to locate the printer.
This is usually caused by the printers IP address changing.
Changing the boot method to static will make sure the IP address on the printer does not change.
Now we will have to make sure the computer knows where to find the printer.
On your computer, go to your start menuè control panelè printer
Here you should see your brother printer. Right click on the printer and select “properties” (If you are running windows Vista, make sure select “run as administrator” and then properties)
Go to the “ports” tab
Select “add Port…” and then double click on “standard tcp/ip port”.
This will bring you to the add port wizard, click next.
In the field for “Printer name or IP address” enter in the new IP address of your printer and then press next and finally “finished”.
Make sure to apply the changes.
You should now be able to print.
Thank you,
Mar 28, 2010 | Brother MFC-685cw InkJet Printer
Brother MFC 8860 has ip conflict. How do I resolve this? The issue is that the IP address is different on my computer versus the printer and thus doesn't allow them to connect. Greg
Sep 10, 2009 | Brother MFC-8860DN Printer
"brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Apr 17, 2009 | Brother MFC 7840W Printer
BROTHER MFC 420CN WILL NOT PRINT FROM LAPTOP
I had the same problem and what I found was that the IP address I used did not agree with the IP address stored in the printer. You can find the IP address using the setup TCP/IP option from the menu button. I changed the IP address in the TCP/IP port properties and it worked. I don't know how it changed, but I suspect the IP changed because of a conflict. When I turned the laptop off the IP went back to the original one that I had been using.
Apr 15, 2009 | Brother MFC 420CN All-In-One InkJet...
Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
I went and got static IP addresses from internet provider...Must of caught them on a good day
Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother 845cw printer is offline -
Had same issue and here is what worked for me.
1. Go to Printers and right click on Brother printer and choose 'Properties'
2. Click the 'Ports' tab and with proper Brother printer port highlighted click 'Configure Port'
3. In second field titled "Printer Name or IP Address" enter the IP address of printer*
4. Click 'OK' as need to exit out.
I'm using XP so this may be slightly different depeneding on your flavor of Windows. The main thing is to name the port with the IP address and not rely on name resolution.
Hope this works for you too!
* If you don't know your printer's IP address then you can go to your printer and under the 'Reports' section print-out the Network Configuration report to find IP address.
Feb 29, 2008 | Brother MFC-845CW multi-function...
294 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
