Question about Whirlpool 30 in. RC8700 Electric Cooktop
I have an old Kelvinator self-cleaning stove (free satnding). It is about 15-20 years old. I just tried to use the self cleaning cycle and the door latch has locked and cannot be opened. The clock on the stove alsop does not work, Help????????????? I need to get the latch open! Note: it did not go through a cycle as the catch on the door itself is bent and it did not lock the door........ this stove has been used by a tenant of mine for 4 years with no other problems.
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 06, 2009
richroth
  • 9472 Answers
SOURCE: i acidently turned on the self cleaning mode
What is the model number posted on the unit?
Posted on Feb 02, 2011
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Feb 11, 2016 | Frigidaire Gas & Electric Stove/Oven/Range...
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Nov 08, 2014 | General Electric GE 24" Single...
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Jun 24, 2014 | Kenmore White Electric Stove
I have black swirl scratches from using abrasive sponge on front of black oven door
There is this white stuff sold for glass-top stoves. I presume it is good old iron cleaner, a very mild cleaner/polish. Also consider toothpaste.
Dec 01, 2013 | Amana 30" Self Cleaning Electric Range...
How to get the F9 err off when i press the button clean for my oven
The F9 code indicates a problem with the door lock. (Since the oven must lock the door for a cleaning cycle, this will be a "fatal" error for the cleaning cycle.) There are a few possibilities. Open the oven door and look for a L-shaped piece of metal on the top of the oven frame. Check that this lock part is angled to go straight up (12 on an analog clock). If it is rotated slightly, it won't fit properly during the lock cycle.
Clean the latch and wiggle it to check if it will move freely. If these steps don't fix the problem, you need to check the door latch motor and switches. You will need to take off the back panel of the oven to find the motor. Check for loose wires or damaged/loose switches.
If the motor assembly and switches are good, then the central control (clock) probably needs to be replaced.
I hope this helps.
(most self-cleaning ovens will eventually have a problem with the lock assembly.)
Sep 24, 2013 | Frigidaire Stove/Oven/Range Cooktop -...
The lock light is blinking, the door is locked, everything is turned off, and the temperature is definetely below 490. We cannot get the door to open. I have a E36DF76EPS model
Hi
Thanks for using FixYa. The locking of the oven is a safety measure while self clean function is activated. Once the oven has completed the cycle & has cooled down, then it will reset the door lock.
If a self clean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition or you were not using the self clean cycle, then, the lock must usually be accessed and moved manually to open the door—
In order to open the door you have to open the control panel and remove the door lock.
Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
The door lock is secured by the three screws.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 26, 2009 | Cooktops
How do I know when my stove is done self cleaning?
to get all the detailed instructions
just click this link directly
http://www.applianceaid.com/selfclean5.html
thanks.
Nov 11, 2009 | Kenmore Cooktops
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
Thanks
Rylee
Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Whirlpool 30 in. RC8700 Electric Cooktop Logo
159 people viewed this question
Top Whirlpool Cooktops Experts
vince
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
