Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
When trying to use oven f1 code would display...could reset and ove would work...tried to use broil one day heard loud pop and it quit working
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
SmartSet control has malfunctioned and oven stopped working
The best way to reset the control is to unplug the unit from all power sources. Let is set for about 30 minutes to an hour. And then plug it back in. If you still have the same problem you are most likely going to have to replace some electronics.
CH
Jul 30, 2008 | GE 30" Self-Cleaning Freestanding Electric...
Cant clear code or use oven after small power surge - stove top still works. GE web site does not have a F81 code they have an F8 and F1 which both say problem with keypad and electronic control needs to...
You didn't post model, but with a surge you probably looking at replacing the ERC. Does the manual say to unplug to reset, or check again on reset the control.
Some have this for reset, can't hurt to try.
  • Press the BAKEand BROIL HI/LO pads at the same time for 3-5 seconds until the display shows SF.
  • Press the COOKTIME and BROIL HI/LO button (on some models press Broil only, refer to your use and care manual). The display should show C. Press the button again until F shows in the display.
  • Press START to complete the change.
  • If this clears control, do it again to reset to Fahrenheit.
    This way actually resets for a error also besides temp.
    You can check the price of a control here,
    http://www.repairclinic.com/
    And you can google search for more places to shop prices.
    Mar 30, 2013 | Ovens
    Error code f1 e3
    Try this out,
    FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
    per wiring diagram before performing the following steps:
    STEP 1 Power off and wait 5 seconds.
    STEP 2 Power on and wait 5 seconds.
    STEP 3 Press the following keys:
    CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
    NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
    STEP 4 Press START.
    STEP 5 Make sure Timer ID is the same as the oven.
    STEP 6 Press CANCEL to exit.
    Nov 27, 2012 | Kitchen Ranges
    Oven went out with a pop
    Did someone bump the self-cleaning lock lever? If you have one, make sure it is all the way over to the right. Try resetting the unit by tripping the breaker. Leave it off for 30 secs min and turn it back on. See if that works. If not, let us know and we'll help you further.
    May 18, 2010 | Frigidaire Kitchen Ranges
    Hello! We have a Kenmore stove, model #92320 and
    Dec 22, 2009 | Kenmore 92320 / 92321 / 92322 / 92324...
    Electric Dbl Wall Oven-loud popping noise at end of self clean
    Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
    Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    MAYTAG STOVE PROBLEM...NEED HELP
    the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
    Mar 05, 2008 | Kitchen Ranges
    Frigidaire code F1
    Rainbow, F1 could be one of three things. The loud pop doesn't sound good. 1. Shorted keypad-replace the control. 2. The control sensed a runaway oven temp. In this case you would have to ohm out the temp probe. 3. The control itself may have a shorted relay-replace the control. The temp probe should ohm at approx 1100 ohms at room temp. Unplug the oven for one minute, if the code returns, first ohm the temp sensor (probe) if that checks ok, replace the control..Catriver
    Nov 30, 2007 | Frigidaire FEF355 Electric Kitchen Range
    Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
    82 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Mike Carew
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
