Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
The oven is 100 degrees colder then the read out
  • Steve Allison
    Steve Allison May 11, 2010
    You failed to give us the model number so it isn't possible to make any sensible diagnosis.
  • 126 Answers
Press bake and set to 550degrees. within 2 seconds press and hold the bake until 2 digits show on display, then release bake. the digits displayed is the amount of degrees the oven is off from original factory setting. If it reads 0, it is at original factory setting. you can now adjust by pressing the up button for a hotter oven, down for lower. it can only be done for 35 degrees. when done, hit clear/off. this will help to close the gap. if you are using an inexpensive thermometer, it can take a very long time for it to read the actual temp in the oven.
Posted on Nov 15, 2009
Y please convert oven degree from 1-8 to centigrade(ARISTON oven 95GT01----
0 degrees C is freezing and 100 degrees C is boiling
Jul 26, 2014 | Ovens
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
Turn oven on to 350. It clicks and goes to 100. Stays at 100 and never heats up.
Assuming a digital oven with a thermometer: The 100 degree reading is probably the lowest reading the thermometer will register.
Don't give me a poor rating because I said your question was poor. Include as much information as possible including basic description of appliance and model number. Try different things and state what works as well as what does not work.
In this way, you can get better answers. As is, I know nothing about your oven except that it does not work. My keyboard will not fix your oven. It would be helpful if you convince me that you are not afraid to physically enter your oven and touch things.
:o)
Jun 03, 2011 | Maytag Ovens
Not the right temp in the oven 100 degrees off
I have a kenmore gas range with digital display that will let me increase the temperature up to 35 degrees f*. It says to press BAKE for 6 sec., then use the number pad to increase or decrease then press START.
Hope this helps
Don
Jan 05, 2010 | GE Ovens
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Aug 10, 2009 | Belling XOU270 / XOU271 Electric Single...
How to turn oven on kelvinator wall
Is there a hand diagram labelling one of the button. Auto/Manual switch?.
Apr 11, 2009 | Fisher and Paykel AeroTech Double OD302...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
115 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
