Question about Sony Ericsson K510i Cellular Phone
When i go into tools and search for updates it comes on the screen device mgmt. sonyericsson communication interrupted
Why won't my volume wont work on pavilion dv7
Step 1: Using the Troubleshooting tool in Windows 8 The Troubleshooting tool in Windows 8 can automatically fix common problems with your computer, such as audio recording. Although it may not fix every problem, it is useful to run the Troubleshooting tool first before you manually correct problems.
To open the Troubleshooting tool:
  1. At the Start screen, type find and fix audio to open the Search charm. Figure 1: Find and fix audio search
    c04030165.jpgShow all ' Hide all [img id="doc_plus_doc_sc_6.1" src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/hpweb_1-2_plus.gif" alt="show" >
    Update the audio driver from the HP Web site
    [/a] hpweb_1-2_plus.gif
    Update the audio driver using Device Manager in Windows 8
    Step 4: Checking Device Manager to troubleshoot audio problems (Windows 8)
    If you cannot hear sound, check Device Manager to determine the state of the sound hardware.
    1. At the Start screen, type device manager to open the Search charm. Select Device Manager in the Search results. Figure 13: Device Manager
      [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/95/c04030167.jpg" alt="Device Manager on the Search screen" title="Device Manager on the Search screen">
    2. Double-click Sound, video and game controllers .
    3. Do the following, depending on what displays:
Jul 14, 2014 | HP Pavilion dv9000z Notebook
Firmware interrupted on steelseries raw keyboard now keyboard has no power..just wont work
Here is the solution, It may help, use a different pc or laptop...
and then ran the firmware fix from steelseries.heres a link cdn co steelseries com
Apr 10, 2014 | SteelSeries Apex Raw Keyboard
Pcm wont communicate with car
probably just need to update the Tech 2 software or try to use a different one. If not check the wiring behind the DLC
Jan 24, 2013 | 1999 Saab 9-5
It wont do any updats
You may need to reset your console, when it first comes on, there is an icon at the bottom of your channels screen, i believe it is an icon that looks like tools. you will have to reset it. even on the console you can reset it with the red button. once you do it, turn it on and click for updates. sometimes it takes a while but please let it finish or it could cause problems if you interrupt it. also when you see your wii lighting up blue it is doing automatic updates, just let it finish
Nov 08, 2009 | Nintendo Wii Console
Unable to use phone book contacts between Nokia 5800 and Parrot 3100
You need to check that both the 3100 and the 5800 are using the latest software. There were problems with the older software but they have been resolved.
On the 5800: Settings>Phone>Phone mgmt.>Device updates>Options>Check for updates (Assumes your 5800 has a working internet connection). Othewise use software updates from Nokia PCsuite.
For the 3100: Download the software update tool from www.parrot.com to a bluetooth enabled notebook. Run the update tool and just follow the instructions. If you don't have wireless internet on your notebook, run the update tool first while connected to the net to download the update files before taking the notebook into the car. The 3100 must be in software update mode before you connect the notebook via bluetooth. Settings>Advanced settings>Software Update>Activate.
I found that it took a couple of attempts to get the connection to work, but once it was made the update completed fine. The 3100 then resets itself and you need to pair the 5800 again. Once it's paired, the contacts will synchronise.
I did this about 30 minutes ago, so I know it works.
Good luck
Nov 08, 2009 | Parrot Hands-Free Car Kit with LCD Display...
I have problem with touch screen settings so its not working i would like to know how solve problem
You may need to update /reinstall firmware on your device. Use SE PC Suite and choose SEUS (sonyericsson update service).
Oct 21, 2009 | Sony Ericsson P990i Cellular Phone
TI-83 Calculator RAM cleared
To clear the message press [CLEAR]
If calculator shows message after you turn it [ON], it may be due to drained backup battery. If you have to change it make sure you have main batteries in and in good state, and installed.
If calculator appears frozen, press [2nd] [QUIT] to interrupt what it is doing.
I see you do not have the latest ROM (OS). You should download the latest ROM (1.19) and install it.
Use the education.ti.com link to download the TIConnect software. Install it on your computer. Run the TIConnect software. Connect the calculator to a computer (USB cable or TISilverLink cable or TI Graphlink black cable). Press the ON button, do not worry if you do not see anything on screen (contrast may be too light).
In TIConnect main window, click the TI Device info button. The software will try to detect the calculator. If the answer is NOT FOUND on any of the ports, click the communication settings at the bottom of the window.
Select Device: enter you calculator model
Select Cable: SilverLink, USB,
Select port : USB1 or COMx
and click OK. The TI connect software will give you some messages if communications with calculator cannot be established.
If you establish communications with the calculator, press the Update button in TIConnect main window. Install OS directly to the calculator. You may update other installed applications.
If you cannot communicate with calculator with the computer try to update by cal-to-calc connection with a working calculator/
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-83 Plus Calculator
Device Management
if it indicates that it hasn't actually sent anything to us yet.
The common sync phases for Sony Ericsson devices are:
  • Synchronising
  • Sending
  • Receiving
  • Sync Complete
you would have to double check all of the connection settings in use on the device and also ensure they are correctly linked to the sync application (some devices require that the settings are enabled for the sync application).
Oct 13, 2008 | Computers & Internet
Software up dates for k800i
download the Sony Ericcson Update service from http://www.sonyericsson.com/cws/download/1/110/61/1211192682/Update_Service_Setup-2.8.5.12.exe
then install it, then follow the on screen prompts
Oct 05, 2008 | Cell Phones
Sony Ericsson K510i Cellular Phone Logo
55 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
