Question about Leviton Decora Gray Rocker 4-Way AC Quiet Switch
I am connecting three switchs to control one light. how do i connect using a 4 way switch
  • 484 Answers
The wiring method is power into the first 3-way switch, 3-wire to the 4-way switch, 3-wire to the second 3-way switch and 2-wire to the lamp. The way you terminate the wires on the switches is only important on the black terminals of the two 3-ways. Power and load go on these, the rest are just travelers.
Posted on Nov 16, 2009
  • matthew kuhl Nov 20, 2009
    (power)----(3-way switch)====(4-way switch)====(3-way switch)----(lamp)
    There is a black screw and two brass screws on the 3-ways and four brass screws on the 4-way. The black screws on the 3-ways are for the power coming into the first switch and the power going to the light on the last switch. The brass screws are for the travelers between switches. Using 3-conductor cable to link the three switches, follow the instruction on the boxes the switches came in. There are different manufacturing methods for these switches, so you have to do it the way they tell you to. The neutrals (white wire) just get tied together in each box.
Lights not working @ top of stairs
Pull the covers off the switch boxes and remove the switches but don't disconnect them. Look to see how many wires are connected to each switch. A two way switch should have 3 insulated wires connect to each switch AND a bare copper wire for ground. If you don't have that configuration, then it was not built correctly.
Jun 28, 2015 | Home
How do i wire multiple lights on one three way switch
Multiple lights are just connected in parallel to the first light off the three way switch. See my article on how to wire two 3 way switches to control one light and then just connect more lights to the last light. Remember not to add too many lights to the circuit. Check the amperage rating on the switches being used.
Jun 09, 2014 | Electrical Supplies
Trying to replace dimmer switch with regular switch.2 black one red (hot) wire. only two terminals. how do I connect these 3 wires
Hi Carl
I'm an electrician and can help you with this problem. It sounds like you've got a "3 way" circuit - that is; you control the light with 2 or more switches (assuming all three wires were not connected to each other - but had individual connections to three screws or three wires on the dimmer).
If this is the case, you need to replace the dimmer with a 3 way switch. A 3 way switch has 4 terminals - one is a green hex-headed screw for ground, 2 others are golden or brass screws for the black wires and fianlly a black or significantly darker screw that is for your red hot wire.
A 3 way switch has no ON or OFF markings on the handle. If the replacement switch has such markings, or has only 3 screws (ground and two golden or brass colored screws) it is likely a single pole switch; and will not work with the other switch(es) to control the light. You will need to obtain a 3 way switch before continuing and wire it as described above.
If you have further questions, leave them in a comment & I'll give you more help. Good luck!
Jun 28, 2012 | Electrical Supplies
I have a 1755 3 rocker switch, http://communities.leviton.com/docs/DOC-1920, that I'm trying to install in place of an older switch. Here are the pictures for both, the new switch and old one:...
Ledio, I am unable to access specific photos on Picassa
https://plus.google.com/106982528064073343888/posts
I have downloaded instruction manual for 1755 rocker switch
This is ordinary triple-rocker-switch to control 3 different loads.
It is like having 3 single pole switches and each switch controls a separate light (Load)
This is single pole switch for 120Volt, and not suited necessarily for 240Volt loads.
Switch is not for 3-way application as typically found in hallway where 2 switches control same light.
1) You have 4 wires.
Electricians don't guess, they test.
There are 4 types of wires in 120Volt and 240V household wiring: Hot wire, Neutral wire, Load wire, and ground wire.
Load wire means the wire that connects to switch and goes to Light, fan, motor (load)
Hot wire always connects to one side of switch.
Neutral never connects to switch.
Load wires connect to side of switch opposite Hot wire.
Bare copper ground wire connects to any green ground screw.
2) One-and-only-one wire in each 120Volt electrical box is Hot. (assuming you are not replacing
3-way switch or working with 240V)
3) Separate all 4 wires for testing. Tape tester leads to wood sticks. Turn power ON.
Test each wire to bare ground wire. Tester will light up on Hot wire.
4) Hot is identified. Next, find the neutral wire if it is among the 4 wires.
Test Hot wire to all other wires in box, except bare ground wire.
Tester will light up on neutral wire.
Tester will not light up on Load wires.
5) NOT EVERY switch box has a neutral. Or the neutral wires can be twisted together and covered with wire nut and pushed to back of box.
The neutral may be up in the light fixture. Neutral located in ceiling box is typical with bathroom fan-light-heater combos.
If neutral is not one of the 4 wires, then don't worry about the neutral connection because it will already be wired together.
6) Image of 1755 switch shows 1 screw terminal on the Hot side, so connect Hot wire to this single screw.
Other side of switch has 3 screws for connecting each of 3 Load wires.
Note: Neutral wire is NEVER connected to a switch.
http://www.frostelectric.com/WOE-IMAGES/00381764.jpg
7) Since I cannot see wiring project or know what loads or how the testing comes out, I suggest connect the Hot wire to single screw terminal.
And then connect 1 of the other wires to other side of switch. Not a neutral.
Turn power ON, and try switch.
Process of elimination might yield result.
8) Add a comment with more question, and it sends e-mail. I will respond.
More resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html
http://waterheatertimer.org/images/How-to-wire-double-rocker-s.jpg
Sep 25, 2011 | Electrical Supplies
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
I need a diagram to install a Westinghouse 3-way light switch (#77052) on a lighting fixture on the bottom of a ceiling fan. I did not do the removal of the light fixture so I don't know how it was wired...
If by a 3-way switch, you mean a switch with 4 steps of brilliance: off, low, medium, and high when used with a 3-way bulb. The black wire of the switch is connected to incoming power wiring hot wire. Most often also black. The red switch wire connects to the center contact of the lamp socket. The blue wire connects to the small pin connection that is physically between the center connection and the screw shell of the lamp socket. The screw shell is connected to the incoming white wire of the house wiring.
Dec 30, 2010 | Westinghouse Electric Ceiling Fan 3-way...
How do a wire a second emergency shut off switch to my furnace
Try wiring a "Three-Way" switch as follows
Option 1. Fixture Controlled by Two Switches: Power Through a Switch Box
Two three-way switches control one light with the electric power coming through the first switch, flowing to the second switch, and then to the light fixture. The ground wire goes through both switch boxes and the ceiling light box and it is connected at all junctions, except the light, with a pigtail (short piece of wire) and wire connector. The hot wire in the drawing is black and is connected to the COM terminal. The neutral wire is white. Track each with a finger to its conclusion at the light fixture to ensure proper connection.
Nov 16, 2010 | Heating & Cooling
II have a switch and dimmer and the three wires from fan and light, no instructions how install it.
You will have power coming in through a black wire and white wire on the cable set that does not go out to your fan. The black will connect to your switch to power it. Then there will be two other terminals on your switch one for your fan and one for your light. The red and black that go out to your fan and light are connected to these two terminals. The whites get connected together. If you mix the red and black up and the switches are controlling the the wrong things, simply switch the black and red wires. (Note: If by three wires to your fan you meant black, white and bare copper this dual switch cannot be used, as bare copper is simply a ground wire and cannot be used as a constant electrical conductor.)
Jun 05, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
Wiring Bathroom light/vent/heater switch with 3 separate controls
Wiring a bathroom combination vent, heater, light 3 way switch means more wires. In brief, you need to run two cables - one a two wire and one a three wire from the switch to the fan.
Incoming power will have white black and ground.
The two wire cable for the switch to the fan will have wht, blk, and ground.
The three wire will have red, blk, wht, and grnd.
The switch will likely have 2 blacks and a red coming from it, with two blacks and a red on one side, and a single black on the other.
The fan should have a red, blue, green, black, and white.
On the fan end: Group all green/copper grounds together and use a wire nut to fasten them together. Tape the nut to the wires.
There will be five white wires coming through. For ease of handling, using wire nuts, connect two on one nut and three on the other.
connect the blue to a blck. Connect one red to one black, and the other red to the other black.
The switch will have one red going into the 3 wire cable, a black going to the 3 wire cable, and a black form incoming power to the side opposite the 3 wires, and a blck going to the two wire cable.
There. Confused?
May 26, 2009 | Broan-NuTone FAN CONTROL SWITCH
Leviton Decora Gray Rocker 4-Way AC Quiet Switch Logo
212 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
