Question about Mitsubishi WS-55859 55" Rear Projection Television
Mitsugishi vs 50607
Wont turn on green blinks click and does not turn on
  • Mitsubishi Master
  • 8,617 Answers
Push Input and menu together and see if it gives you a two digit blink sequence. You will need a manual you can get one at this link plus support http://servicemanuals.vstore.ca/
Posted on Jan 10, 2008
6ya staff
SOURCE:
Mitsubishi vs50705 turn power on green button comes on then it shuts off quickly
TRY the self check here, this model may have it.
When green light comes on and goes off, on front of set press and hold both the menu and input buttons for at least five seconds and release both buttons.
Watch the power light, if it has the self check feature it will blink a two digit error code.
The most common is two blinks, two blinks, a pause and then repeat several times.
Let me know if find a error code.
SD TECH
Jan 16, 2011 | Mitsubishi VS-50607 50" Rear Projection...
AFTER TURNING ON TV ,THE GREEN LIGHT COMES ,SOUND STARTS AND THEN TV TURNS OFF ASAP
after tv shuts off press and hold menu and input buttons on tv at same time for about 8 second. power led will start to blink error code 12 ok 22 dead short 23 deflection failore 24 vertical failore. after you know error code have electronic technition repair for you. J.D.W.
Jun 24, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs-50707
see a tech you need one they will come and take the panel off and thake the light box with them because you have a circiut problem
Feb 25, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Power shut off right after turning on
If the unit is not overheated, you may have the dreaded green blinking light (sometimes never stopping blinking). Usually, it takes a capacitor kit to fix this (assuming you have that problem), which is available for many models on the internet. Mitsubishi may be of some help also as this sounds like a common problem.
Jul 18, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
Feb 11, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Vs-50607 turns off by itself it might come on after about 8hrs
if you hold menu and input on the front panel it will blink a code to tell you
where the error likely is. hold the buttons for 5 seconds and you'll get a 2
digit error, like 1 2 = no error..
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
let me know what you find.. it will determine area of failure
Jan 08, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I have a Mitsubishi VS-50607 and it will turn on then off.
This solution fromtroylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Vs 50607
might be the convergence ic's
Oct 12, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607
Oct 04, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 Won't Turn On
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
