Question about LG WM-1832C Front Load Washer
Water level for a front load LG washer?
Just got our new LG front load washer. We've never had one before, should I be able to see the water level rising, like at the laundmat or does the water level stay low? I know it's a silly question, but hey...I'm kinda silly.
  • 1,294 Answers
You're not silly. You could hv said which country you are from..... The water level is usually low, except when the rinsing takes place, when it comes to about half at the glass window. Make sure you turn on the faucet on the wall full when you operate the machine; you can close faucet after wash. (dont forget to open when u begin next wash!!)
Posted on Jan 09, 2008
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
Lint, and debris not going to filter
Generally speaking grass clipping etc will stay in tub on a hi efficiency washer. That's why the water level is very low also-high efficiency,low water use. Most LG washers have an extra water button to add a small level of water per wash.
Jan 16, 2018 | LG SteamWasher WM2650H 27" Front-Load...
How do you adjust the water level on an LG front loader washer?
You cant, water levels are factory set for optimum water efficiency, new machines use a lot less water than older machines, poor wash results are usually caused by over loading
Oct 17, 2013 | LG WM-2277HW Front Load Washer
The water inlet Solenoid is open. Check the Solenoid. Give gentle tap it may re seat again. Finally replace if it is not settling!
Apr 05, 2010 | LG WM-1832C Front Load Washer
My front load LG Washer has a mildew/musty odor. I have taken great care of this washer since the purchase in September 2004. I cannot get rid of this odor and now it is in my clothes. I have been using...
Make about 3 quarts of boiling water on the stove. Pour one cup of bleach, and a few capfuls of pine sol into the washer (just pour them directly into the washer through the front door.) Now, if you have a faucet near the washer, turn on the hot water until the water is hot- then turn it off.
Now start a "hot" load, and after the water starts to fill, pause it, and add the really hot stove water. This will raise the water level high enough to wash off all the gunk that has built up between the spinning inner barrel of the washer and the outer barrel in which it sits.
For future reference... only use HE detergent, never use liquid fabric softener, always take the clothes out as soon as possible after the load is finished, and leave the door open when you are done.
Front loaders are kind of known for this problem.
Jul 22, 2009 | LG Washing Machines
Lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
Oct 01, 2008 | LG WM-2277HW Front Load Washer
L g steam washer front load
The model you have this listed under WM2688H (LG Steam Washer) a E1 Code Correct water level (246) is not reached within 8 minutes
after water is supplied or it does not reach the preset water
level within 25 minutes.
I suggest you
Check the screens in the water inlet valve for blockage
Feb 18, 2008 | LG WM2688H Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
LG WM-1832C Front Load Washer Logo
150 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
