Question about Zanussi F1045W Front Load Washer
Light on, turn dial n nothing happens ..no noise, zilch
  • 460 Answers
This machine needs a new timer. or, maybe a door switch.. call a service tech...
Posted on Nov 15, 2009
Hi, I have a Candy Grand comfort which has just stopped working. the power is there lights on but when I turn the dial it clicks as if to start but nothing happens. Thanks in advance.
Could be the door interlock or simply there is no water entering the machine. Check water supply and also the vales inside the machine . the solenoids should buzz nd hum a little if they are energised but could still be blocked ???
Dec 18, 2016 | Candy Washing Machines
Just pressure washed my recently acquired honda gb 500. and the motorcycle will not start,not even light up the dial,no neutral light,lights absolutely nothing zilch checked the main fuse that seems ok. I...
The Maine fuse is probably blown for blade fuse u can check with test light very easy same with barel fuses ohm meter work the same way except they tell voltage ohm amp on a ac or DC current battery's are DC cure plug ur red and black leads in to the meter turn it to 12v DC take the black one and ground it to frame or negative side of battery now the red one will let u fine hot wire if it's hot it will show voltage reading u can touch either side of fuse it should be hot on both sides one side should show voltage regardless with key on if fuse is blown it won't so on other side
/uploads/images/just-pressure-washed-recently-acquired-34845734-1-1.png
/uploads/images/just-pressure-washed-recently-acquired-34845734-1-2.png
Jan 06, 2015 | Motorcycles
Duet dryer won't turn on. has power from outlet. but dryer has nothing . No lights . Nothing. Nada . Zip . Zilch.
remove the front door and screws securing the door to the front cover,then remove front cover and look for the thermal cutoff fuse as if this is open it will kill all power to unit,it should be on the blower wheel housing
Dec 07, 2012 | Dryers
My LG Washer isn't working. The little chime that rings whenever it is turned on happens but then NOTHING else. No lights, no codes, nothing. I spin the dial but there's nothing, no noise and no lights....
the machine has suffered a power failure?push and hold the main power button plus another button together hold both buttons in for about 60 secounds the machine should reset.adrian.
Mar 16, 2011 | LG Washing Machines
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Will not turn on
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Dryers
When I turn on the unit and attempt to press 'A' on the controller to proceed, nothing happens. Zilch. Nothing lights up on the controller. Batteries are good.
see if the batteries are in backwards. if not, then it could be the controller. could have been dropped a few to many times, or banged around. electronics can go through a bit, but too much will render them useless eventually. good luck.
Oct 15, 2009 | Nintendo Wii Console
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Zanussi F1045W Front Load Washer Logo
95 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
