Question about Compaq Presario 5000 PC Desktop
What is total of ram memory, for sps-bd 1394 motherboard
    Novelist:
  • 186 Answers
Your manual should tell you how large a chip can be put in. It's usually either 1G strips or 2G strips. You have to do some homework.
Posted on Nov 15, 2009
How much ram available on toshiba L755 motherboard
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L775-L770-L775D-L770D/laptop-disassembly-1.htm
Click on the photo in Step 3.
There are TWO Ram memory modules that can be installed.
EACH ram memory slot will support 4GB of ram memory.
TOTAL for the motherboard is 8GB.
Uses SO-DIMM ram memory modules that are PC3-10600, or PC3-12800,
http://www.crucial.com/store/listparts.aspx?model=Satellite%20L755&Cat=RAM
Regards,
joecoolvette
Sep 19, 2012 | Toshiba Computers & Internet
Compaq system board 686,0MB (320756) board manual
That's an old mainboard (Motherboard), used in a Compaq Presario 5716 desktop computer. (And perhaps a few other Compaq Presario's)
1) Uses a Slot 1 (Intel) processor slot.
http://en.wikipedia.org/wiki/Slot_1
2) Maximum Intel Slot 1 processor that can be used, is an Intel Pentium III, with a 100MegaHertz Front Side Bus. (100MHz FSB)
Maximum frequency rate for the processor is 700MHz.
('Speed')
http://www.cpu-world.com/CPUs/Pentium-III/TYPE-Pentium%20III%20%28Katmai%29.html
(Scroll the page down)
3) Ram memory is SDR Sdram at 100MHz. Or also known as PC-100. (168 pin. 82 on each side. Two Locating Notches on bottom. Commonly just known as Sdram, but that is a misnomer)
http://en.wikipedia.org/wiki/PC100
Maximum TOTAL Amount of ram memory is 384MegaByte.
Maximum Amount for each ram memory slot is 128MB.
There are 3 ram memory slots.
4) Do not know what the jumper settings on the motherboard are.
5) Do not know what the Front Panel header pinout is.
6) Can run Windows XP Home Edition, but do not expect a world of performance.
Regards,
joecoolvette
Jun 10, 2012 | Compaq Computers & Internet
How to know that the ram can match with your motherboard?
This motherboard supports DDR200/266/333 SDRAM
The memory needs to match one of these numbers so:
DDR200
DDR266
DDR333
one of these types will work
This motherboard will support a maximum of 4GB of memory.
Apr 13, 2011 | ASUS VIA KT333 Chipset A7V333...
How many slots for dram chipsets? For AZ11/ AZ31 motherboard? Thanks!
FIC AZ11 (First International Computer {Inc}
3 Ram Memory slots.
Supports SDR Sdram at 100MegaHertz, or 133MHz. (PC100, and PC133 respectively)
Maximum Total Amount is 1.5GB
Maximum Amount for EACH ram memory slot is 512MB. (1/2GB.)
Uses the VIA KT133 motherboard chipset,
(Northbridge - VIA VT8363
Southbridge - VIA VT82C686A/B)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Socket A processor socket for AMD processors. (Also referred to as Socket 462)
http://www.xbitlabs.com/articles/mainboards/display/fic-az11.html#
FIC AZ31
3 Ram Memory slots
Same type of ram memory as above, same total amount, and amount for each ram memory slot.
Uses the VIA KT133A motherboard chipset.
(Northbridge - VT8363A
Southbridge - VT82C686B
Socket A processor socket.
http://en.wikipedia.org/wiki/Socket_A
http://www.baber.com/baber/411/fic_az31.htm
Oct 30, 2010 | FIC AZ 11E Motherboard
The right type of motherboard for compaq presario 2200 pc
Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371793-001 System board (motherboard) - De-featured (DEF) for Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original
Mar 02, 2010 | HP Compaq Presario 2200 Notebook
Beep codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
May 14, 2009 | AOpen AX34-U Motherboard
I Have a Motherboard K7S5A xp 1800 I would like to now if it will hold 2x1gb of ram for a total of 2gb of ram Please Help Thank You
No, Maximum memory on this board is 1GB total. There are four memory expansion slots (places to put memory sticks.)
Mar 14, 2009 | EliteGroup K7S5A Pro Motherboard
ASUS P5L-VM 1394 mother
Here is a link to a website that identifies the specs for your motherboard, and also identifies the type of processors that are compatible with your motherboard. It is Intel Core 2 duo/ Intel Core 2 duo Extreme capable.
It looks like you have a good candidate for a gaming pc, in my opinion. I would suggest that you upgrade the memory to its max of 4 GB. This link also has a list of all compatible memory modules for your motherboard, If you click on a memory module, there is an option on the next page to tell you where you can buy it and for how much.
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=32522&mfr=ASUS%2FASmobile&model=P5L&root=&LinkBack=&Sys=32522-ASUS%2FASmobile-P5L-VM+1394+Motherboard&distributor=0&submit1=Search
Apr 11, 2008 | ASUS P5E-VM DO Core 2 Quad Socket 775...
Compaq Presario 5000 PC Desktop Logo
89 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
